Help! Replacing front bearing on 4Runner
Old May 19, 2009 | 05:02 PM
bringles's Avatar
I have a 97 4runner limited 4x4. I am trying to replace the front wheel bearing. The trouble I am having is finding the part. I have ordered two bearings, one from advance auto parts and one from Toyota. My mechanic says that the bearings are too big to fit. I have attached a photo of the bearing that we are trying to replace.
What is going on? Could there be two bearings? Is my mechanic an idiot? Which side does the bearing slide out from, brake side or axle side? Any help would be appreciated.
Old May 20, 2009 | 03:12 AM
GSGALLANT's Avatar
There is only one bearing per side. Once you get the axle hub pressed out, and you remove the bearing spacer and ABS ring, you'll be able to see things more clearly. You'll then need to remove the seal and snap ring on the outboard side of the spindle, then you press the bearing outward (towards where the rotor would be). To install the new bearing, you press it in from rotor side, and re-install the rest of the parts in the reverse order that you took them out.
Are you planning on trying this with the spindle still installed on the vehicle? It's a lot easier with the spindle on a bench, and even much easier if you have access to a press.
Old May 20, 2009 | 07:06 PM
Kerby J's Avatar
there is also a clip inside of the housing tht no parts sheets have on them and they r bout 7 dollars from toyota and if u replace a bearing then u have to get them bc when u pressit out it tears it in halh and cant be reused
voiddweller
19
May 2, 2016 09:10 PM
Iceman4193
Jun 28, 2015 10:30 AM
TheManOutside
Jun 18, 2015 03:32 PM
Mohamed
Jun 20, 2002 10:42 AM
