Help remove/install 95 4wd tacoma front wheel bearings
Old Nov 22, 2014 | 12:19 PM
BigHoss_27's Avatar
Need information or someone that has replaced on before to explain what to do the Hayes book I have is very vague on how to do it
Old Nov 22, 2014 | 01:38 PM
wyoming9's Avatar
Red face
Do you have the manual Hubs or the ADD system??
Makes some difference.
It also depends on the production date of the truck if you have the newer sealed bearing or the old style bearings able to be repacked in the normal manor.
Just what are you working pretty easy to tell by looking.
Old Nov 22, 2014 | 03:56 PM
rworegon's Avatar
BigHoss, take a look at this link and try finding a resource that will help you out on your projects. The Haynes or Chilton books just don't cut it most of the time.
The steering knuckle with axle hub attached must be removed from the vehicle as the bearing is pressed in. You deal with that nut on the backside after the knuckle assembly is off the rig.
Old Nov 22, 2014 | 07:50 PM
BigHoss_27's Avatar
Thanks for help I'm pretty sure I got how it goes now. But where can I get the castle nut on top of knuckle as it was messed up getting it off
Old Nov 22, 2014 | 08:31 PM
rworegon's Avatar
Your local Toyota dealer has or can get just the castle nut for you.
Old Nov 23, 2014 | 10:19 AM
BigHoss_27's Avatar
Can the dealership undo the nut with the four holes in it
Old Nov 23, 2014 | 10:57 AM
rworegon's Avatar
Yes, dealer certainly can. It's a lock nut socket with 4 prongs and front end alignment shops/machine shops will have the socket most likely. Or, it may be available at your local auto part store for purchase or maybe even for rent.
Old Nov 24, 2014 | 12:47 PM
BigHoss_27's Avatar
Thanks and does the lock nut unloosing to the left or right
Old Nov 26, 2014 | 06:38 PM
aowRS's Avatar
I replaced both front bearings/seals/clips a few months ago - without removing the steering knuckle.
I purchased the OTC Hub Grappler kit and then sold it after the job was done.
Andreas
Old Nov 26, 2014 | 06:45 PM
BigHoss_27's Avatar
Well goods news is it's done bad news machine shop I took to tore it all to hell and were complete ass holes
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Gamble_STi
Jul 7, 2015 07:54 PM
skoti89
Jul 6, 2015 07:45 PM
