help my truck wont STAY running
Old Feb 21, 2005 | 06:50 PM
sniper95688's Avatar
HI EVERYONE I HAVE A 88 TOY 4RUNNER. 4X4 4CYL 2.4 LITER AUTO. I WAS DRIVING IT TODAT WHEN THE CHECK ENGINE LIGHT CAME ON AND THE TRUCK DIED. IT WILL START BUT IF I PUSH ON GAS IT WILL DIE. IT WILL ALSO DIE AFTER TWO OR THREE SECS AT IDLE. I HAVE FUEL PRESSUREA AND JUST REPLACED FUEL FILTER. WHAT COULD THIS BE THANKS.
Old Feb 22, 2005 | 08:43 AM
ekim121's Avatar
vacuum leak perhaps...when I did my headgasket my friend and I were mystified as to why my truck would run for ~3 seconds and then die. Turned out we missed a vacuum line.
Old Feb 22, 2005 | 09:07 AM
phorunninduke's Avatar
Read the codes, this site should help , and make your life easier. Come back when you get the code and we can help you from there.
Old Feb 22, 2005 | 09:15 AM
MTL_4runner's Avatar
Get the code first and post back with it.
....and don't use all caps, very annoying to read.
Old Feb 22, 2005 | 07:39 PM
sorry about the caps on
i get code 14 and 21. bad igu(ignition control module) and bad o2 sensor. i put in used distributer from junk yard and it now runs. however i noticed that my truck is missing the o2 sensor or it is not where it should be( mounted too exsaust manifold). i will sen a pic of where it should be. i also have a vacuum tube that used too go somewhere that is now going nowhere. i cant figure out where it goes. i will post pics asap thanks
Old Feb 22, 2005 | 08:53 PM
here are pics
pics are ok i can try again but it is hard to upload only 46 kb. sizes
File Type: bmp
File Type: bmp
Old Feb 23, 2005 | 09:15 AM
What year is your truck? that makes a difference where your o2 sensor is. It is either under the heat sheild, or there is one before the catalytic converter and one after. The pictures are hard to see, but the missing wire one looks like it has something to do with cruse control. I cant make out much out in the picture in regards to the vacume hose.
Old Feb 23, 2005 | 09:25 AM
Try posting pics on www.webshots.com or www.photobucket.com in full size so we can see them and help you out.
Old Feb 23, 2005 | 12:22 PM
posted on webshots
hi thanks for info here is lik for those pics http://community.webshots.com/user/sniper95688
Old Feb 23, 2005 | 01:13 PM
this thread on pirate4x4 has tons and tons of pictures of 22re and you can probably find alot by looking at them.
http://www.pirate4x4.com/forum/showt...8&page=2&pp=25
Old Feb 23, 2005 | 02:17 PM
those pics are great but none show where that line goes
Yont283
Sep 23, 2022 08:06 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Jdgarrison
Oct 1, 2015 05:22 PM
serenity03k64
Jun 27, 2015 07:59 AM
Land yacht
Jun 28, 2002 09:53 AM
