Help with installing hellwig sway bars!
Old Jun 24, 2004 | 09:58 AM
nags's Avatar
Ok, I just tried to install these things and they are garbage. The powdercoating is coming off, wasn't even dry all the way. The instructions SUCK. All B/W pictures and they are so dark you can't see anything. Got about halfway through and just took everything off and put it in the box.
Anyone that install these have any tips or anything? If you could take some nice quality pictures of the finished install it'd really help.
thanks
Old Jun 24, 2004 | 01:58 PM
nags's Avatar
anyone?
Old Jun 24, 2004 | 02:28 PM
914runner's Avatar
Are they stock replacements?
If so I would assume it is just, unbolt the stock bar, remove it, put up new bar, bolt it in.
Old Jun 24, 2004 | 04:11 PM
nags's Avatar
No, they aren't stock replacements... they mount up to the axle and the frame
Old Jun 24, 2004 | 06:39 PM
Jeff B's Avatar
I installed these on my 02' Dbl Cab about a year ago. The instructions with mine refered to springs on the end links that they no longer use...
The only tricky part is the drivers side pinch bracket, it's real close to the shock and you will not be able to mount it at 90* to the frame.
Once you get it installed you'll like it, it improves the handing greatly.
-Jeff
Old Jun 24, 2004 | 07:04 PM
nags's Avatar
the mounting brackets you have look completley different from mine... mine are also so close to the spare tire it looks like they are going to rub
Old Jun 24, 2004 | 08:00 PM
Jeff B's Avatar
Yes, the bracket is close to the spare.
That picture isn't of my truck. I posted it because it clearly shows the overall setup and my photos are blurry. The parts are the same. Here's a shot of my truck, drivers side.
Old Jun 24, 2004 | 08:04 PM
nags's Avatar
Are the drivers side and passengers side brackets facing different directions? The insturctions seem to tell you to do it like that.. they say to make the drivers side facing towards the back but facing forward seemed to fit better
Old Jun 24, 2004 | 08:32 PM
Jeff B's Avatar
Both brackets face the same direction: toward the front, parallel to the frame.
I circled the part of the bracket facing the front.
Old Jun 24, 2004 | 08:37 PM
nags's Avatar
Cool.. thanks a lot for the pics.. they help more than any directions.
The instructions pretty clearly say that they'll be facing different directions but it did not make sense at all
on the passenger side.. where do you have the long bolt going? between the exhaust and leaf springs?
Old Jun 24, 2004 | 08:49 PM
Jeff B's Avatar
Here's what I'd suggest:
Drop the spare so you'll have room to work.
Assemble the whole thing, and start by attaching the U bolts to axle, this will position every thing. (Tighten the nut on the end links just to the point the bushings start to bulge.) Once the U bolts are on, you will see that the pinch brackets are only going to meet the frame in a certain spot. Adjust the bar up or down to move the pinch bracket forward or back so you get maxium bite on the frame.
Yes, the end link on the passenger side goes between the leaf spring and the tail pipe
Hope this makes sense...
Old Jun 24, 2004 | 09:39 PM
nags's Avatar
I'll give it another go tommorow.
thanks again
Old Jun 30, 2004 | 12:44 PM
nags's Avatar
Working on it now.. how the hell do you use these locknuts?? just tighten till they finally go on?
Old Jun 30, 2004 | 01:47 PM
nags's Avatar
this thing is a ˟˟˟˟˟ing bitch to install.. argh
Old Jun 30, 2004 | 02:47 PM
nags's Avatar
How do I adjust these bolts? they are top and bottom on both sides but I dont know how far up or down to adjust them
I've only got a few extra locknuts so I'm doin' pretty good :pat:
Old Jul 1, 2004 | 04:01 AM
Jeff B's Avatar
You don't want to over tighten these, tighten until the bushing starts to bulge.
The bushings need room to squish with suspension movement.
Maybe they included extra nuts? They're Nylock nuts aren't they?
Old Jul 1, 2004 | 04:05 AM
Jeff B's Avatar
Just looked, they're not Nylock. Look closely at the picture and you'll see the first nut on the endlink the thinner lockng nut.
You will need to gently bend the brake line on the passenger side of the axel to slip the U bolt on...
Old Jul 1, 2004 | 06:29 AM
nags's Avatar
yea, but I'm asking where on the long spacer do I want them? right on the end? halfway? etc... instructions dont say anything
Old Jul 1, 2004 | 08:34 AM
Jeff B's Avatar
Center them on the threaded part.
Old Jul 1, 2004 | 12:37 PM
nags's Avatar
center them? ˟˟˟˟. I've got them on the very ends right now
nvdesertrunner
May 11, 2020 08:18 PM
4.34runner88
Aug 11, 2018 10:44 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
