HELP!!! I can't shift into 4 wheel drive
Old Nov 26, 2003 | 05:56 PM
waycan's Avatar
Unhappy HELP!!! I can't shift into 4 wheel drive
Last night it snowed pretty heavy here. So on my way to town I tried to shift into 4 wheel drive..... and nothing!?! There was no light on the dash and it definately had no power to the front wheels. It was quite icey and the rear end would kick out with ease. I pulled over and tried shifting into low and still nothing. I tried shifting in and out of 4 high and 4 low in all of the gears too and it did not make any difference. Has anyone had a similar problem or does anyone have any ideas on what could cause it.
Thank you
Old Nov 26, 2003 | 06:20 PM
AverysDad's Avatar
i think a common problem with the ADD on toyotas (which i asume you have on your truck) is a vaccum leak which wont allow the front end to engage properly.
try a search and see what you get for answers.
p.s. ----(its the green flashing button up top)
Old Nov 26, 2003 | 06:48 PM
yeah it is most likely what Averysdad said. There are plenty of posts on this.
good luck, driving with only rearwheel traction is a bit scary in the snow.
C
Old Nov 26, 2003 | 07:27 PM
AznSky's Avatar
did you try it in park as well? That was my problem, for some reason I just can't shift on the fly anymore. Shift to park, shift to 4-hi, then put it into drive.
If that doesn't work, then I would have to agree with the vacuum hose theory.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
