help! horrible squeeling sound!
Old Jan 25, 2004 | 06:21 PM
INsr5runner's Avatar
I have this horrible squeeling sound from my front right wheels. I got her up with a hilift today, and spun my tire around, and it still squeeled. That makes me think that my rotors are warped.
What should i do? I am ordering new brake pads ASAP, to see if that will help.
Any other suggestions?
Old Jan 25, 2004 | 06:24 PM
cubuff4runner's Avatar
It is probably your pads. Most brake bads are designed with a small piece of metal that will hit your rotor before they are completely shot. This metal is meant to make a horrible sound so you take it to the shop before the pads go completely bad and ruin the rotors and lose your brakes.
Old Jan 25, 2004 | 07:04 PM
AznSky's Avatar
yay time to wrench more!
Old Jan 25, 2004 | 07:54 PM
Pretacopower's Avatar
Re: help! horrible squeeling sound!
Crap....I guess that explains the squealing from my front tires too. Do you feel shuddering when braking?
I think I need new rotors as well....so much for the new exhaust I was planning on
Old Jan 26, 2004 | 12:17 AM
Tacoma Dude's Avatar
First time I heard mine I was super paranoid and fixed it within 24 hours. I thought I'd only hear the screeching noise when I braked but I was hearing the sounds bouncing off barricades as I was driving by them.
Took off the old pads and got a good look - realized I could have gone a good number of miles more on them if I needed to.
Less than $60 in pads and 3 hours (trying to figure it out while working on it) was all it took
Old Jan 26, 2004 | 01:40 AM
Mossback74's Avatar
The good thing about the disc brakes is that (once you figure it out) they are really easy to change. After a couple changes you get down to 15 min a side
Old Jan 26, 2004 | 02:39 AM
MTL_4runner's Avatar
Re: Re: help! horrible squeeling sound!
If the brake pedal vibrates during breaking then that is rotors for sure.
Otherwise it is just the pads....make sure to use some anti-squeel when you assemble it again.
You can check how much pad life is let just by pulling a wheel.
Should take about 3hrs the first time you do it......much less later.
Old Jan 26, 2004 | 04:51 AM
i figured it was the pads, especially after wheelin hard last weekend. I thought it might be warped rotors, in which case the only thing I knew to do was replace them.
irv
Sep 29, 2015 01:04 PM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
Wardog
Sep 6, 2015 07:57 AM
