HELP getting off ROAD TAR!!!!
Old Mar 7, 2004 | 02:20 PM
Tencast's Avatar
I must have gone through some construction over the weekend and my baby is smothered in road tar. What do I use to get is off without hurting the paint?
BTW I already did a search and didn't find anything.
Tank you tank you so so much
David
Old Mar 7, 2004 | 02:34 PM
ofcbarbrady's Avatar
I don't remember the brand-----it's a yellow can with a black top---bug and tar remover--works great. I used it on my Cobra numerous times and it didnt hurt the paint one bit---just make sure your car is cool and you follow the directions. Rinse it off completely after letting it sit for about 30 seconds.
Old Mar 7, 2004 | 04:03 PM
WT's Avatar
WT
David
WD40 work well too just wash it all off good and give it a coat of wax
Old Mar 7, 2004 | 04:07 PM
WSU4runner's Avatar
Try using 3M adhesive remover or maybe clay. I've used that at work and it worked really well.
Old Mar 7, 2004 | 05:50 PM
evilcow's Avatar
wd40 or mineral spirits
tombothetominator's Avatar
solvent and/or gas will do the trick, just dont let them sit more than a few minutes, and make sure to wax. At least thats what i use as a car-wash boy by occupation.
Old Mar 7, 2004 | 05:52 PM
MTL_4runner's Avatar
Ditto on the WD-40
Old Mar 7, 2004 | 07:38 PM
fooddude's Avatar
what cant wd-40 do. Seems like you can use it on anything these days.
Old Mar 7, 2004 | 11:52 PM
X-AWDriver's Avatar
I've used 3M adhesive remover but you gotta be careful and used minimal rubbing or it does start to scuff the clear coat.
Old Mar 8, 2004 | 05:09 AM
calg3's Avatar
Simple Green always works for me, WD40 is awesome, too.
http://www.simplegreen.com/products/...ousehold1.html
Old Mar 8, 2004 | 06:57 AM
cruizin01's Avatar
Claying works "ok" I would probably use something more abrasive like wd-40 or something and then clay and wax...If you dont want to wax it I wouldn't use any of these chemicals.
Old Mar 8, 2004 | 11:49 AM
Highland Runner's Avatar
Try mineral spirits first, then WD-40 or Goo Gone. I used mineral spirits for years to remove pine tree sap. Wash after to remove the mineral spirits then wax.
Old Mar 8, 2004 | 12:16 PM
Fink's Avatar
Is that the same stuff that you can use to clean the engine bay? I've been lookin around and thats the only stuff I have found...
Sorry for hijacking,
WD40 or Goo Gone will work wonders!
Fink
EDIT: I feel like a dumba$$...after reading about 2 pages into the Simple Green website I found out that "Engine Degreasing/Cleaning" is listed...wow...I need more sleep!
Old Mar 8, 2004 | 05:36 PM
WSU4runner's Avatar
Not to jack this post but on a similar note how can I get off the leftover adhesive from the factory stickers?? I've tried adhesive remover but it didn't do much and I probably spent a good two hours on it. Anything better out there??
Thanks
Old Mar 8, 2004 | 08:47 PM
calg3's Avatar
Well, I hate to keep repeating myself but WD40 works really well on that, too. I used WD40 to remove the adhesive that was left on my 4Runner after I removed the Gold Emblem package. I also use it to get gum out of clothing.
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
JamesDINAN
Sep 22, 2015 05:37 AM
altydog
Sep 20, 2015 07:37 PM
