help! cv stuck in diff!
ok guys the cv axle is ready to come out but it is stuck in the diff. I have been trying to pry with a pry bar but it does nothing. is there something else i need to do? every write up says it will just slide out....i have a 96 4runner 4wd
I've came across this a few times at work. The best solution I've found is to use a pickle fork and a 5 lb. mini sledge hammer to jar it out. This only works if you are replacing the whole axle though and not just putting a boot. I would recommend buying your own pickle fork instead of using a "loan-a-tool" from autozone or somewhere because you WILL damage the prongs on the fork.
May have to turn it a bit, make sure it's the right one. Measure the old cv shaft and compare it to the new one. Depending on where you got it from (autozone, napa, etc.) they may have given you the wrong one.
I had trouble getting mine to go in when I replaced them. I found that the retaining or snap rings that are located on the end of the shaft were spread out too far. I took them off and put the old snap rings on and the axle popped in with no problem. Good luck.
live4soccer7
May 11, 2016 06:52 PM
Odin
Sep 26, 2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
