HELP! Cant pass inspection
Old Jul 29, 2009 | 07:36 AM
flowingmotion's Avatar
Exclamation HELP! Cant pass inspection
I need my inspection sticker but both my plate lights are out. The screws are totally rusted out. Anybody know another way to get at those bulbs?
'99 4runner limited
Old Jul 29, 2009 | 07:51 AM
jibbles's Avatar
try PB blaster or a hammer
Old Jul 29, 2009 | 08:08 AM
Godzilla's Avatar
I dont think I would use a hammer, but PB and an EZ out may be helpful.
Did you strip them?
Old Jul 29, 2009 | 08:13 AM
I tried soaking them and using an ez out but they are so rusted they just turn to dust. I wrecked one and decided to stop.
Old Jul 29, 2009 | 09:20 AM
bgmac's Avatar
You could always just drill them out and then just use a size bigger screw when you go to reinstall them.
Old Jul 29, 2009 | 09:31 AM
seanmearse's Avatar
Not sure if this works, but, read somewhere if you cant get a screw out, put some valve lapping compound on the bit.
Old Jul 29, 2009 | 11:18 AM
I'm thinking I'll just try to take the head off the screws so I can at least get the cover off and get at the bulbs. Then I'll worry about a more permanent fix later.
Old Jul 29, 2009 | 07:54 PM
cutter's Avatar
you can notch the heads with a dremel and use a flat head to unscrew them
Old Jul 30, 2009 | 04:40 AM
That's a good idea. I tried that but the rust was too deep and the top of the head basically disintegrated.
I ended up taking the heads off the screws and got the covers off. I have new bulbs and electrical tape holding it together until I can get the new screws.
I'll post if I pass or fail.
Thanks for all the good advice.
Old Jul 30, 2009 | 08:30 AM
Passed inspection. Thanks again for the help.
bryan34w
12
Sep 30, 2015 02:50 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
Dobich
Sep 14, 2015 11:15 PM
Boomer8404
Sep 10, 2015 09:01 AM
