Old Mar 30, 2016, 03:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Transmission Guides
Print Wikipost
help! 95 Toyota Tacoma v6 3.4l 4wd automatic transmission
Old Jul 5, 2014 | 08:51 PM
RoadRageRock's Avatar
So went to store and when i pulled into parking lot and got out left truck idle while i ran in and when i got back outside i could hear a lound grinding sound from motor turn off truck and back on was quite for about 20 sec and its back lound grinding sound. On the way home i had no power steering and batt light comes on when i turn to the left. When i got home opened the hood to look and see if I can pinpoint the sound but nothing noticeable can anyone help!!!!"
Old Jul 5, 2014 | 11:16 PM
Ok so I found out the problem. Did some research and found some stuff on harmonic balancers. So I had to go look and sure enough loose real loose. Removed the belts. And it was just hanging, but the bolt is tight. Can i just get a new HB.
Old Jul 6, 2014 | 09:09 AM
help! 95 Toyota Tacoma v6 3.4l 4wd automatic transmission-forumrunner_20140706_100721.png
help! 95 Toyota Tacoma v6 3.4l 4wd automatic transmission-forumrunner_20140706_100759.png
So here it it, the problem looks bad how can i go about this HELP"!!!!!" Please
Old Jul 6, 2014 | 01:23 PM
rworegon's Avatar
Yes, you will need a new HB, IMHO. Also, the timing belt (TB) will need to come off so the crank gear can be pulled so the key can replaced (it's mangled in pic 1).
Might just be a good time to do the TB, etc. if it's getting close to the next change interval.
Old Jul 6, 2014 | 04:13 PM
scope103's Avatar
Not cheap.
http://www.toyotapartsoverstock.com/...340862040.html
For that kind of money, I'd consider a salvage yard.
I think you'll need to carefully examine the key-groove in the crankshaft. It it has been banged up, the key won't fit tightly, and the wobbling of the crankshaft pulley will quickly loosen everything.
Good luck!
Old Jul 6, 2014 | 05:20 PM
rworegon's Avatar
Some have purchased the non-OEM HB from RockAuto.com in the past. It's $161 + shipping.
kawazx636
Oct 6, 2021 03:03 PM
Kamaloha
Oct 16, 2015 05:13 PM
LCE_Performance
Oct 1, 2015 01:03 PM
tylermx71
Sep 29, 2015 08:49 PM
toyotasaurus
Sep 24, 2015 03:30 PM
