hella 500 install
Old 12-10-2002, 05:50 PM
doink's Avatar
hella 500 install
hey guys. just got some hella 500 driving lights today, and im trying to figure out how everything goes together before i install. got a question. do i have to ground the switch?. thanks in advance.
oh, and on an other note, i finally got my car back from the shop. now im 4inches higher pictures are soon to come
Old 12-10-2002, 06:01 PM
runninclean's Avatar
You only need to ground the switch if it's a lighted switch. If you're switch is not lighted then there is no need for a ground and you only need to ground the fog lights themselves. If you have anymore questions just post away.
Old 12-10-2002, 06:05 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Hi Doink, lots of posts here on the Hella 500s
First thing, throw away the green switch they gave you.
You will have to drill a hole in your factory switch cutouts to install it, and why not just use a factory switch that goes in place of the cutouts?
Look on my website in the mods section for a JPG that shows you how to wire up the factory Toyota switch you can buy for $12 at your dealer.
The JPG with the switch will be on page one of the mods.
Old 12-10-2002, 06:21 PM
doink's Avatar
yeah, i think im gonna do the switch thing. but tomorrow, i want to hook everything just to make sure it works and everything is hooked up correctly. man, my piaa''s were so much easier, but then again, im kinda dumb. my piaa's are wired to my parking lights, im assuming i can do the same with the hellas?
Old 12-10-2002, 06:25 PM
Staff
Corey's Avatar
No need to wire the power wire in the switch JPG.
Tap into a in cab fuse down by your left foot.
If you only want the lamps to work with key on, tap the wire behind the cigg fuse.
If you want the lights to come on without the key, find a fuse that is hot all the time.
Tapping to a fuse does not over load it, as the tap is not what powers the lights.
The tap is only for a small amount of juice to energize the 30 amp relay which in turn powers the lamps.
Corey
Old 12-10-2002, 06:28 PM
doink's Avatar
corey-
dumb question, what do you mean by tapping a fuse.? ha, i bet i know , but, im just a little unclear.
Old 12-11-2002, 04:33 AM
CTB
CTB's Avatar
He means to strip a little bit of wire off one end, wrap it around one of the fuse blades, and then put the fuse back into its place.
Old 12-11-2002, 09:19 AM
joshik's Avatar
use a T connector to tap into a wire. you can buy them at any autostore in the electrical section. those come in REAL handy!
Old 12-11-2002, 09:42 AM
UKMyers's Avatar
Ya I didn't no this. The light in my factory switch stopped working and I took it apart and found that my ground had pulled loose from the connector. I was under the impression it would not work without the ground but the light is all that doesn't work.
Old 12-11-2002, 04:00 PM
stanlyboggs's Avatar
Hey Doink, i love hella 500's tell me how you like them, I was thinking of getting some of my own:tomcat:
Old 12-11-2002, 04:27 PM
CTB
CTB's Avatar
The 500's are great, especially for the price. Try a search and you will come up with a ton of info on Hella lights.
Old 12-11-2002, 04:30 PM
doink's Avatar
thanks for all the info guys. tomorrow im going to jump into the installation. i will let you guys know how it turns out.
stanly boggs....is this the same stan i know? hah
Old 12-12-2002, 12:13 PM
doink's Avatar
help!
well, just got back in from attempting to install the hellas, yet no light. i think i have everything correctly wired and stuff, anything i should try to do over again? thanks
Old 12-12-2002, 12:29 PM
CTB
CTB's Avatar
Is the fuse good? The original one I had was bad, and it took me about 30 minutes to check something so obvious...
If you want to bring it up here to SC, I'll help you out
Old 12-12-2002, 12:40 PM
doink's Avatar
CTB-
where is the fuse located? what part of SC are you from?
Old 12-12-2002, 01:01 PM
CTB
CTB's Avatar
I'm talking about the fuse in the wire that you ran from the battery to the relay. I am in Clemson, SC, which is only about 20 miles or so from the border with GA.
Old 12-12-2002, 02:09 PM
doink's Avatar
i checked the fuse, all was good. hm, thats not to far from me..heh anyway, any other possiblities? im going to check the grounds for my lights. is there a really good place toground your lights that others have had success with?
Old 12-12-2002, 02:25 PM
Staff
Corey's Avatar
See the two blue wires in my picture here?
The wires that are above each headlight.
One goes to the battery clamp down bracket, the other one goes to the coolent puke jug hold down clamp.
Those are my two ground wires for my bumper mounted Hella's.
Also check to make sure you have the relay wired up right.
http://www.pnw4runners.net/tech/hella_lamp_scan.jpg
Where they show wire #8, that is the wire that gets the power from tapping into the headlamps.
That wire goes to your switch.
But I do not have mine that way.
I have mine tapped into my underhood aux. fusebox with full time power.
This way I can turn the Hella's on anytime without my key.
Where did you tap that wire too?
You can tap it to a fuse in your incab fuse box as discussed earlier.
Which switch did you end up going with?
Corey
Old 12-12-2002, 02:33 PM
CTB
CTB's Avatar
Corey's post explains it all. If you have any other questions, PM me or post here - we'll help you get it figured out!
Old 12-12-2002, 02:44 PM
doink's Avatar
hey corey, i tapped into my parking light wire, the same one that i used for my piaas. like this set up, i only have to have my parking lights on for the aux to run, or atleast that was the case with my other lights. for now im just using the switch they supplied with the kit, although, i will eventually get that toyota one. im going to try to put the ground wires where you put them corey, and maybe that will do the trick. thanks for helping me with this guys.
Quick Reply: hella 500 install
