Heavy Duty Leaf Springs
Old Oct 13, 2004 | 01:44 PM
brendonv's Avatar
Is there a company out there that makes affordable rear heavy duty leaf springs? Or anyone know of a company that makes brand new stock ones? I dont want ones that will give the rear much of a lift though.
1987 Pickup
Brendon V
Old Oct 13, 2004 | 03:50 PM
Wildfire's Avatar
ARB OME makes nice pieces. Not real cheap and a slight lift over level. Maybe not what you want, but first class parts.
Old Oct 13, 2004 | 06:05 PM
kyle_22r's Avatar
this a 2wd pickup? if so, you might want to look for some leaves from a 1 ton pickup, as they were heavier-duty
Old Oct 13, 2004 | 06:06 PM
SoCal4Running's Avatar
Check out your local yellow pages.
Old Oct 14, 2004 | 02:55 PM
Flamedx4's Avatar
Northwest Offroad makes exactly what you're looking for.
Old Oct 14, 2004 | 03:10 PM
cvlighthouse's Avatar
the add-a leaf spring works great. Downey or Rancho make them... Easy install
Old Oct 15, 2004 | 01:57 PM
Flamedx4's Avatar
Add a leafs make for a rough ride though. You can add load-helper springs from companies like Hellwig. Northwest offroad does make 2 stage heavy duty springs with no lift, I know of no one else who does.
Old Oct 15, 2004 | 02:21 PM
kyle_22r's Avatar
it's just unfortunate that NWOR is the only company that seems to sell low and no-lift springs these days, except for OME
Old Oct 15, 2004 | 02:53 PM
Flamedx4's Avatar
True.
On the other hand, makes little sense to buy new springs to get no lift.
"HOney, come check out the truck now!"
"YOu spent $500 on...what?!! Looks the same to me..."
If I needed to carry more weight, I would buy auxiliary air bags. Second choice would be load-helpers springs.
Old Oct 15, 2004 | 10:04 PM
amusement's Avatar
I have successfully used www.activesuspension.com kit. The cost was under 300 USD. THey worked beyond my expections with trailers and heavy loads on a 95 toy 4x4 extra cab. Easy to install and never fail.
Suggest you give them a try. I don't think you will regret it.
Old Oct 16, 2004 | 04:34 AM
brendonv's Avatar
thanks guys...now check out my other post for my other problems!!!
Zach_trun
Jan 22, 2020 04:42 PM
Scottcrb
Mar 3, 2016 11:57 AM
briholt
Sep 20, 2015 10:26 PM
potatopants
Sep 15, 2015 06:26 AM
