headgasket problem
Old Feb 19, 2004 | 10:11 AM
silverCRXTC's Avatar
headgasket problem
Ok, my yota truck (22re) blew the headgasket the other day, and i put a new one in (what a PITA) put back on the Intake, rotor and every thing, turn the key and just turns but doesnt try to start.
Things im sure of
1. The rotor was set to fire on cyclinder one, its at TDC and the cam timing is corect.
2. pretty sure all the vacuum lines are hooked up correctly.
3.) the gasket was torqued to 58ft/lbs
4.) i changed the fuel filter (what a poor location )
Any help would be appreciated, help me get my truck running again
Old Feb 19, 2004 | 11:15 AM
bump any ideas?
Old Feb 19, 2004 | 12:07 PM
dick's Avatar
You should try and ask this question out on http://www.t4x4pickup.com/
in the Toyota discussion forum. Those guys love to answer questions such as yours. Lot of expertise out there to. Give em a try.
Old Feb 19, 2004 | 02:50 PM
85runner's Avatar
I would be willing to bet that the timing is 180 degrees off.
Old Feb 19, 2004 | 03:31 PM
86toyota's Avatar
I agree with 85runner ,make sure its on the compression stroke.Take out the plug,stick finger over the hole and have someone bump the ignition till you feel comp. on that cyl.
Old Feb 19, 2004 | 05:25 PM
4x4CPOSEADOG's Avatar
Posted by 86toyota
Whoa, this is dangerous! Sticking your finger in the hole and bumping the ignition is dangerous! You will be one less finger and a lot of pain.
Why not get a socket and a breaker bar, put the transmission in neutral, put the socket and breaker bar on the crankshaft pulley and rotate the crankshaft until you see the timing mark line up. Just my .02 cents
Noel
Old Feb 19, 2004 | 05:49 PM
86toyota's Avatar
First of all not putting finger in but over to feel the pressure coming out the hole.the timing mark will line up twice in a 360 degree rev one is not the comp stroke that's what is meant by 180 out.
Old Feb 19, 2004 | 05:58 PM
when i took it apart, it was at tdc and the rotor was pointing to piston 1, the cam is at tdc and everything is kosher, ill try it again, hope fully its out 180,
also to do a timing chain do you need to drop the oil pan?
Old Feb 22, 2004 | 03:57 PM
85runner's Avatar
No, Just remove the front two bolts on the oil pan.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
toofly1999
Jul 25, 2015 07:09 PM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
