Headers vs. Stock power increase impression
Old Apr 17, 2004 | 04:08 PM
nigeltufnel3's Avatar
Originally Posted by Duffdog
yes, the cam actually did something, unlike the headers+exhaust+pipe combo that might add 8hp if your lucky. My truck is noticeably faster now with the trd stage 1 cam, that was the best 149 i ever spent.
T
was all you replaced was the cam? did you get new lifters or rocker arms or anything???
Old Apr 17, 2004 | 06:58 PM
partszar's Avatar
The install insructions that came with the cam (22re) said to replace the rockers. I did, that way your new cam is breaking in on new rockers
Old Apr 20, 2004 | 04:58 AM
foxtrapper's Avatar
Guest
Originally Posted by Poke Runner
What I want to know is what's the difference between the $800+ TRD headers and a set that is significantly cheaper? Are you paying for the name or is there a difference in quality or performance?
Collector design is the single most important feature of a header. A cheap junk unit like Pacesetter will have the manifold tubes crimped down into a "collector". These units may flow better then a stock manifold, but not always. A good designed collector will be rather long and have the pipes join it without any crimping, and the gas flow will clearly be smooth.
The stock 22RE manifold is a very good example of a tri-y type header. Its biggest downfall is that it is a small diameter at the base.
The rest of the stuff about ceramic coatings, stainless steel, etc. is all fluff as far as power is concerned. It does matter to life of the header, and for bling.
Old Apr 20, 2004 | 05:18 AM
rimpainter.com's Avatar
Originally Posted by midiwall
Oh my ears perked up here...
I've been toying with the idea of running a more agressive cam. tee-hee.
What kind of hours did it take you to put in?
NX_Tacoma had cam regrinds installed in his 3.4. I dont think he was too happy with them. I cant remember though.
Install will be really fun on the 5VZ.
I installed a cam on my 95 Civic SI and it was pretty easy - even with VTEC.
A multicam V6 - now that's a different story.
Old Apr 20, 2004 | 05:59 AM
  #25
midiwall's Avatar
Hey Christian;
Yeah, I started another thread yesterday specifically asking about cams... In short, I'm no longer interested. It sounds like cams are a good idea on 3.0's and 2.2's, but they're not worth the $$$ on the 3.4's.
Thanks!
Old Apr 20, 2004 | 06:22 AM
  #26
I think we both just need to get the SC and UDR kit and be done with it!
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
DrZero
Jul 13, 2015 09:59 AM
cars-guy
Jul 11, 2015 07:51 PM
