head gasket
Old Aug 1, 2018 | 07:23 AM
matthewwrobel17's Avatar
head gasket
Im working on an 08 forenza for someone doing head gasket should i do bolts to? customer really dont to
Old Aug 1, 2018 | 07:32 AM
75w90mantraN's Avatar
If the service procedure calls for torque-to-yield head bolts it's best to use new ones to avoid sealing issues with the new gasket...among other variables. Old ones generally will not have the same strength as before installation and are reportedly single use only.
Old Aug 1, 2018 | 08:03 AM
I have an 08 forenza with oil in the intake breather throttle body and when i pull plugwires out one by one. every other plug will make the car stall out other two makes no difference doesnt stall does die out nothing
Old Aug 1, 2018 | 08:27 AM
Oil like on a pcv at the crankcase, ok, but at the throttle, not really good. Quite the job you got there. Probably have somebody there where you're at take a look. Be your best bet than on a forum for Toyota's. Can at least hook up a scan tool on that 08 and check for codes. Can help narrow it down. Good luck.
Old Aug 1, 2018 | 08:46 AM
i already did that currently working on answers now
Old Aug 4, 2018 | 05:47 PM
Marc's Avatar
Maybe a Suzuki forum would be a better place for info?
philip64
Jul 5, 2017 06:17 PM
DanDanTMM
May 29, 2017 08:04 AM
SCShaun
May 8, 2017 10:56 AM
TheMaxfield
Apr 13, 2017 09:50 PM
Hungrynomad
Mar 26, 2017 11:56 AM
