Guys with Yakima fairing?
Old Nov 24, 2006 | 06:24 PM
nermalgod's Avatar
The fairings? Yes, even if the size isn't exactly right it will fit. The control towers? No, you will need a new landing pad as the clips for the tracks are not the same. If you are using Q-towers, then you'll need two new sets of Q-clips but you can reuse everything else and if you are using 1A raingutter towers you won't be able to reuse them even though Jason B is doing just that, I highly recommend against it because I have seen lots of damaged caused by using raingutter towers on vehicles without raingutters. The have too much leverage and cause too much torque.
nermal
Old Nov 25, 2006 | 02:52 PM
mikehinthehouse's Avatar
nermal
The control towers are Qtowers.... the bars are 44' wide.... like i said its off a Grand Cherokee.... so the only thing I should have to do is get new Qclips?
Old Nov 25, 2006 | 02:57 PM
nermalgod's Avatar
You'll need two boxes of Q62 clips for a 2000 4-runner.
nermal
Old Nov 27, 2006 | 07:47 PM
nermal
you seem to be extremely knowledgeable of this so one more question if you dont mind Nermal.....
I see the control and q towers... what is exactly the difference? I see that Garrets control towers mount to the factory railing of the luggage rack... where do the Q towers mouns?
Old Nov 28, 2006 | 06:04 AM
  #25
nermalgod's Avatar
Perhaps you should visit www.yakima.com to enter your vehicle. I didn't know the specifics but you said that you had Q-towers already. Q-towers are commonly used when there are no factory racks on a vehicle. In some instances, they can be used instead of another rack option like control towers. There are about a 140 specific clips for different vehicles. For a 2000 runner you would need 2 boxes of Q62. The clips grab onto the door jamb so the roof rack will be further forward than one where the factory typically installs. However you have a roofrack without having to drill holes, it is easily removable, and you can reuse most of the components when you change vehicles. If you have an option between using Control Towers and Q-Towers, I would recommend using Control Towers as they are an easier to use and better looking roof rack. I use a combination of both on my truck because I carry long loads and wanted three cross bars to support my loads. I have a total spread distance of over 9 feet.
I know racks because I install hundreds of Yakima and Thule racks a year. It's part of my job.
nermal
Old Nov 28, 2006 | 06:56 AM
  #26
sweet... yeah Ive been checking out Yakima.com... I think Im gonna go with the control towers... they look cleaner and attach to the factory rack like you where saying... thanks for all of your input
mikeh
montanatruck
Feb 26, 2017 07:07 AM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
scottyg486
Jul 19, 2015 05:34 PM
timmJ
Jul 7, 2015 02:01 PM
