grrrr: 5vzfe timing issues
Thanks for the advice....What was worrying me was the fact that my friend told me that with the belt off they should spin easily...The problem is that they dont obviously bc of the compression.. HE said that if you felt any resistance to stop...but from what you are saying there will be bc the plugs are in...so if i take out the plugs and set cyl 1 to TDC i should be able to move the pully's? If i feel resistance should I keep going....and that tensioner is a pain in the ass to get off...can i just lower it to a few threads on the bolt and then when the belt is on just tighten it back up or do i have to remove it? to bad that snap on tool is so damn expensive
Yes you can back off of the tensioner to remove all possible pressure leaving a couple threads in to keep it there...
After you go through the motions of getting it all lined up turn the crank bolt without the plugs in clockwise 2-4 complete turns back to TDC and recheck all marks are properly lined up before reassembling the front of the engine!!!
I will stress not to worry it is a non-interference motor
If it has a timing belt in a toyota it is non-interference and if it is a timing chain it is interference!!! so if you do not know what that means interference means that the valves will make contact with the piston and non means it will not!!!
just be sure to double and or triple check the timing marks before reassembling so you do not have to take it back apart and redo it!!!
Regency
20
Jan 3, 2020 07:43 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
2000, 5vz, 5vzfe, belt, bolt, crankshaft, difficulty, engine, fe, problem, problems, replacement, specs, timing, tool
