Grey wire mod question
Old Mar 28, 2006 | 04:43 AM
HOJU's Avatar
I did this a while ago but Sunday was the first time i really needed to use the locker. I was wondering if the locker light will go solid or not? It just kept on blinking at me.
Or did i do something wrong?
I followed these instructions- HBoss.net
Old Mar 28, 2006 | 09:21 AM
DrBeau's Avatar
the locker light goes solid. Sometimes it takes a little bit of coaxing to get it to lock though, especially if you don't use it all the time.
To test it, put the truck in 4LO and see if the locker will engage. You may have to slowly move back and/or forward to get it to lock. When the light goes solid, the rear is locked. If you have the radio off and the window down you can also usually hear it engage.
Once it works this way, try going back in to 2WD and engaging it.
I've done this mod and it works like a charm.
Old Mar 28, 2006 | 03:46 PM
rowdy4runnin's Avatar
i tried this mod and for some reason it perma-4wdrived me. i was driving around town in 4wd and COULD NOT get out of it. i wired it back to normal and its fine now. i BELIEVE i followed the directions perfectly because i checked and re-checked but couldnt figure it out. sorry to hijack just wanted to share my story with this mod
Old Mar 28, 2006 | 04:20 PM
DrBeau's Avatar
Did you possibly ground the wrong end of the wire? You need to ground the wire coming out of the ECU. Also, if you did the wrong wire it may make a difference. If I recall, either my truck or my friends '02 taco (I don't remember which) did not have a "gray" wire; it was like Red/blue or something.
Old Mar 29, 2006 | 12:22 AM
4RUNN!N's Avatar
I think you might have accidently grounded the actual 4WD selector wire.
Old Mar 29, 2006 | 05:00 AM
HOJU's Avatar
I'll take a look at the wires tonight, I've been really busy the last couple of days.
thanks guys, I'll let ya know-
Old May 6, 2006 | 04:34 PM
midiwall's Avatar
Hey Allen/rowdy4runnin - did you guys ever get this working?
I'm revisiting the Diff Lock ECU for something else and tripped over this thread. If you're still having trouble, then know that Beau is right - on the 96, the wire is RED/BLUE, not GREY. It _IS_ in the same position that the HBOSS directions talk about.
Old May 8, 2006 | 03:36 PM
HOJU's Avatar
I have yet to find the time to mess with this, but I do recall that i used the red/blue wire....
Old May 8, 2006 | 05:14 PM
BajaRunner's Avatar
I grounded the red/blue wire in my 96 4runner. Works fine for me...
Old May 8, 2006 | 06:45 PM
d0ubledown's Avatar
yep, mine was red/blue also. i think it was only the tacos that had the grey...not sure though.
Old May 8, 2006 | 09:33 PM
Mr. Bob's Avatar
Did it work OK before you did the "grey wire mod"???
Old May 9, 2006 | 03:02 AM
HOJU's Avatar
It worked just fine but since i did the mod, I've been able to get everywhere I've gone without the need for the locker. So when I actually needed it I noticed that it just kept blinking and i never really felt it engage. I got up the trail, but it got me wondering....
Old May 9, 2006 | 06:18 AM
BennyTRD's Avatar
X2
Old May 18, 2006 | 02:29 PM
HOJU's Avatar
Ok, I finally had a second to check this. I too have grounded the Blue/red wire. IT still blinks and I have not felt it engage. I'll put it back to stock to make sure that it still works... but that blue/red wire didn't or hasn't yet, worked for me....
Old May 18, 2006 | 04:31 PM
BennyTRD's Avatar
It takes a little bit for mine to actually engage after I press the button, but it always locks after a few seconds of driving forward or backwards. Try having just the ignition on, truck not running, then press the button and see if you can hear it lock. It will be audible if it indeed works.
Old May 18, 2006 | 05:41 PM
HOJU's Avatar
I tried that long ago....
Old May 18, 2006 | 10:52 PM
BajaRunner's Avatar
Maybe your locker actuator is bad?!
rushw
Jul 18, 2015 01:46 PM
88yodabasket
Jul 13, 2015 01:32 PM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
