Grease from CV joints after lift adjustment?
Old 09-11-2006, 07:58 AM
Zack_Torro's Avatar
Exclamation Grease from CV joints after lift adjustment?
I have a '98 Tacoma 4WD with a 4" fabtech suspension lift and a 2" body lift. Resently, I added some 33" tires and cranked up the front coil over about and 1 1/2" so as to accommodate the new tires. Yesterday, I noticed that there was a bunch of grease coming from somewhere in the vicinty of the CV boot area on both sides. It's all pretty fresh grease and I haven't taken the truck out on the trail lately so there is no dirt in there. Could the new tires and suspension adjustment cause a tear in the CV itself and cause the grease to leak out? What should I do to fix this problem that has just occured before it gets any worse? Thanks for the help.
Old 09-11-2006, 08:03 AM
Localmotion's Avatar
did you do a diff drop?
Does the fabtech come with drop brackets?
Old 09-11-2006, 08:07 AM
Zack_Torro's Avatar
I didn't do a differntial drop when I install the lift 6 years ago. Is that a difficult proceedure?
Old 09-11-2006, 08:08 AM
Angus1's Avatar
some times when you crank to coil over to high it will cause thr boot fins to rub together and create heat witch will cause the boot to fail.
Old 09-11-2006, 08:11 AM
Zack_Torro's Avatar
Does this mean that the CV joint is going to need replacement? BTW, your catfish is awsome!
Old 09-11-2006, 08:15 AM
no the diff drop is not difficult. IF you have a drop bracket for the front, you might not need it. Do you have a pic of your front set up?
If you dont have a bracket, you definately need to order a diff drop.
www.sonoransteel.com
www.4crawler.com
Old 09-11-2006, 08:16 AM
Angus1's Avatar
i cant say for sure if it will or will not need to be replaced . but a diff drop is an alternetive. but you will give up some ground clearence.
Old 09-11-2006, 08:19 AM
a lot of times, it will just leak out from the angle.
visually inspect it for rips/tears. if there are none, do the drop and watch it for more leakage.
Old 09-11-2006, 08:24 AM
Zack_Torro's Avatar
Sorry I don't have any photos of the frony end. Looks like I have a good starting point to go from. If I don't have the brackets, does to kits come with them?
Old 09-11-2006, 08:25 AM
not usually.
Ive seen fabtec kits that have a drop bracket for the cv's. I guess you have something different.
Old 09-11-2006, 09:14 AM
97Limited's Avatar
I have the same issue with fresh Grease leaking out from the CV boots!! my boots are not torn or ripped!! the grease seems to be coming out from between the diff and the inner section of the boots!! Like where the boot is clamped to the half shaft!!
Old 09-11-2006, 09:27 AM
MTL_4runner's Avatar
Mine have started to do the same thing and my lift is very moderate to say the least. It really isn't a big deal, just cut both clamps, pull back the boots, refill with CV grease (it's a specific grease for CVs, don't just use wheel bearing grease), put on the new clamps and crimp them.
Old 09-11-2006, 12:39 PM
97Limited's Avatar
Thanks for the input!! I'll take a closer look tonite!!
Old 09-11-2006, 04:02 PM
BajaRunner's Avatar
Im confused. There is no 4" Fabtech lift. They make coilovers which get 3" max, and a dropbraket lift with 6". You probably have the 3" coilovers since you wouldnt need to jack up the front anymore to clear 33's with the 6".
So, yeah you do need a diff drop, or just crank down your coilovers a little bit. Your CV boots cannot accompany the extra angle.
Old 09-11-2006, 04:18 PM
wjwerdna's Avatar
yeah, diff drop and new clamps, if you are lucky and its just leaking
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
kirkrunner
07-27-2015 07:59 PM
ksmudrunner99
07-21-2015 05:33 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Grease from CV joints after lift adjustment?
