Got my arms back on! :)
Old Sep 26, 2009 | 01:27 PM
BajaRunner's Avatar
After about 4 years of the Trailmaster lift and the funky 2nd struts they use to replace the upper A-arms, I ended up getting some Fabtech spindles and put the upper A-arms back! I'm stoked. The drive is already much tighter, and now I don't have to worry about popping the mounts off from the old setup (Done it before).
They are super beefy and weigh in at 55lbs each (the spindles).
Old Sep 26, 2009 | 01:35 PM
Fink's Avatar
Looks great.
Fink
Old Sep 27, 2009 | 09:04 AM
eddieleephd's Avatar
time for a good party!! looks great
Old Sep 27, 2009 | 06:57 PM
desertcamper67's Avatar
Looks like it went well. Did this fix your ball joint/control arm bushing problems?
Old Sep 27, 2009 | 07:08 PM
jibbles's Avatar
your 4runner is so beastly
Old Sep 28, 2009 | 12:13 AM
awpsome's Avatar
damm nice how high is that?
Old Sep 28, 2009 | 06:56 AM
BajaRunner's Avatar
DesertCamper --- I had my mechanic friend down the street go over the bushings and ball joints with me, and we did some movement tests to find out that everything was fine. I mean, yeah I could use some new parts since they are old, but they are not failing. I think the main problem was my old lift setup. It was janky and caused a lot of movement. Hopefully they will just align my truck now.
awpsome - look at my sig-line. I have a huge writeup and information on that link.
Old Sep 28, 2009 | 10:34 AM
SnowRunner98's Avatar
Swweet, glad you got er' done.
Old Jan 16, 2010 | 04:12 PM
blackdog42's Avatar
I have been wanting to do this for a couple of years. Glad to see that the mod works. How much did it cost you and where did you get them from? Thanks
Old Jan 16, 2010 | 07:27 PM
JamesD's Avatar
I noticed you broke a rear axle shaft. By any chance before this broke, did you have the rear axle bearings replaced?
Old Jan 16, 2010 | 08:57 PM
BajaRunner's Avatar
Blackdog: I bought them used from TTORA. You can buy them for about $300-400 each from 4wheel parts or Offroad warehouse. :/
JamesD: No I hadn't had my bearings replaced. I'm still uncertain to why the shaft broke. I contacted Toyota, and they didn't have any answers or information. It was a scary situation due to the fact I was driving at about 45 mph when it broke and pulled out of the housing.
Old Mar 30, 2010 | 09:25 AM
Coolidge's Avatar
That is awesome! I saw about your fix on TTORA, and wanted to get some input from you? Im looking into getting these knuckles (before I weld #2 crossmemebr back!) I hate my POS TM lift, was going back to stock, but this may be the way to go?
I bought my truck in San Diego BTW
Has King CO's in front w/Bilstein 5125's rear
Old Apr 2, 2010 | 02:04 PM
Coolidge's Avatar
OH well...back to stock with King coil overs.
FWIW, you CAN reverse a drop bracket lift w/cut crossmember.
You are very lucky to scoop those knuckles u$ed
Old Apr 27, 2010 | 09:28 AM
Coolidge's Avatar
Its going quite well....
[IMG]http://img.photobucket.com/albums/v25/Guyster/crash2_10_2010027
.jpg[/IMG]
Kit:
Man, I "hope" its straight! lol
Just back from alignment. Heres a complete pic. Same wheels, no spacers, 285's instead of 35's. Best off, no more DB kit
Hytenor: Align specs before
Align specs after:
Old May 1, 2010 | 08:28 AM
BajaRunner's Avatar
Wow, nice job dude.... !
If I really disliked the DB lift, I'd go that route.
bigjstang
Jun 2, 2025 03:56 PM
razorman8669
Jul 12, 2015 12:13 PM
Kluch8651
Jul 9, 2015 10:39 AM
ptb12
Jul 5, 2015 01:49 PM
elwood73
Jul 5, 2015 07:07 AM
