Got locked up today...
Old Jul 15, 2010 | 05:13 PM
scottishb's Avatar
Yep, I finally took my locker off the kitchen table and put it in the 4Runner. It's nice and noisy! How much fluid does it take to fill the rear diff? I put the funnel on and started dumping, the funnel filled up pretty quick. I held the funnel there for a minute, but it didn't take too much fluid. Is there a better way to do this? I tried to make a little air gap between the funnel and the fill hole to make sure the fluid went in...
Old Jul 15, 2010 | 05:24 PM
kawasakimoto_7's Avatar
well i doubt its any different on the 3rd gen 4runners than the 3rd gen pickups so i fill mine until fluid starts pouring out of the hole..and for putting it in i just cut the tip of of it and squeeze it in there..
Old Jul 15, 2010 | 06:24 PM
VSU_4runnin's Avatar
e locker 1.5 quarts.. non elocker 2-2.5 quarts
check your owners manual... its full of wonderful info like this tid bit
Old Jul 15, 2010 | 08:13 PM
fireball's Avatar
VSU, shame on you for suggesting to read the manual.
Incidentally, where are those wheeling pics taken? Anywhere close to ATL?
Old Jul 16, 2010 | 08:02 AM
scottishb's Avatar
I drain it today and see if enough comes out, and then fill it again. Thanks, guys. Next time I'll look at the manual, there's a lot of stuff in there.
If anybody is wondering if they can do the locker- it's easy. I used an 8mm socket jammed over a rubber cap to stop the brake line from leaking. None of the bolts/nuts were frozen. It kinda sucked putting the case back on, being a half-cripple and all, but I got it single-handed with no jack. Used the driveshaft as a pillow to support my neck... arthritis sucks!
Old Jul 16, 2010 | 08:20 AM
racedirt1's Avatar
Good job, you should bring it out to Cliffs Insane Terrain in Marseilles next weekend for the 4th Annual Chicagoland Toyota Jamboree. There are gonna be a bunch of us there.
Old Jul 16, 2010 | 09:29 AM
scottishb's Avatar
Yes! Now I need to pick up a strap, and then it's off to Cliffs!
Old Jul 16, 2010 | 09:42 AM
racedirt1's Avatar
You gonna make it out the weekend of July 23rd? If so there will be plenty of people with recovery gear so you don't need a strap
Old Jul 16, 2010 | 09:59 AM
scottishb's Avatar
I'll do my best to get out there! Sounds like a good time.
Old Jul 19, 2010 | 05:54 PM
mmml4's Avatar
I use this,
ladybugRC
458
Aug 21, 2020 10:41 AM
PNW94Runner
Sep 29, 2015 02:55 PM
toyotasaurus
Sep 24, 2015 03:30 PM
vikinghug
Sep 23, 2015 12:32 PM
Jason4X4
Sep 17, 2015 08:02 AM
