GM Top End Cleaner
Old Apr 4, 2008 | 07:17 AM
mkgarrison5's Avatar
GM Top End Cleaner
hey guys, can you tell me how to use this? i have read that its much better than seafoam but not sure on how to use it.. do you use it via the pcv valve like seafoam? thanks
mike
Old Apr 4, 2008 | 07:29 AM
rdlsz24's Avatar
Does it say on the can how to use it?
Rob
Old Apr 4, 2008 | 07:32 AM
i dont know. never bought it.. funny thing, the chevy parts guys dont know how to use it and they were to busy to ask a tech... go figure.
Old Apr 4, 2008 | 07:58 AM
rdlsz24's Avatar
I did a Yahoo search and found some of the LS1 guys use it and give instructions on their forums.
Rob
Old Apr 4, 2008 | 08:11 AM
Rob
the instructions are???? damn, i just want a straight answer. i have searched gm top end cleaner and notta. hence the reason why i am asking here. the subject has been brought up before so this isnt new
Old Apr 4, 2008 | 08:15 AM
rdlsz24's Avatar
http://www.corvetteforum.com/techtip...=212&TopicID=1
http://www.ls1tech.com/forums/archiv...p/t-66732.html
http://www.sytyarchives.com/howto/vi...php&dir=engine
http://www.ls1tech.com/forums/showth...167#post487167
Rob
Old Apr 4, 2008 | 08:38 AM
since i do worry about hydrolock unlike these guys.. couldnt i administer this thru the pcv valve with the truck running like seafoam correct?
Old Apr 4, 2008 | 08:49 AM
rdlsz24's Avatar
Yeah that's what the first link tells you to do.
Rob
Old Apr 4, 2008 | 08:58 AM
the way they explained it is different. but thanks man.. i got it now. the 4th link explains it the best..
Old Apr 16, 2008 | 04:36 AM
in their instructions they say poor the last amount in the pcv and let the engine die.. wouldnt that cause hydrolock in our vehicles??
Old Apr 16, 2008 | 07:42 AM
rdlsz24's Avatar
That is how SeaFoam is normally used when you read threads on here. You let the PCV suck it in and then let it sit. When you restart it's a smoke show. SeaFoam is safe to add to engine oil, so it won't hydrolock. I'm assuming the GM is the same way.
Rob
Old Apr 16, 2008 | 08:25 AM
Rob
well thats just it, seafoam is NOT like GM top end cleaner as stated in your links. Seafoam is oil based and Top end cleaner is not. so it is different.. Also if you do the research, it is not ideal to add seafoam to your crankcase (oil) bc it will vastly thin the oil therefore inhibiting your oil to do its job like it is supposed to. (info available on Bitog)... i think you have hydrolocking a little different. from what i was told (now correct me if i am wrong) you do not allow seafoam to choke your motor off nor do you stick your pcv tube in the bottle bc it wont allow air to suck thru causing hydrolock. in your links those guys are inserting the tube into the cleaner fully and allowing the motor to choke off..
chukarhunt
Dec 8, 2019 11:39 AM
montanatruck
Feb 26, 2017 07:07 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
crashburnoveride
Jul 10, 2015 06:39 AM
