GL4 or GL5 gear oil for manual trans?
Old Oct 23, 2004 | 02:05 PM
VolcomTacoma's Avatar
Does it matter if you use GL4 or GL5 gear oil for Tacoma manual transmissions? Ive heard that using GL5 in Toyotas can make your synchros slip making them wear out faster, but that might just be with the older trucks. If I go with a GL4 I am going to run Redline MT90. My 98 Tacoma manual recommends GL4 or GL5 so just wanted your input.
Old Oct 23, 2004 | 02:27 PM
4Crawler's Avatar
I prefer GL-4 oil in all my manual transmissions:
[url]http://www.4crawler.com/4x4/index.shtml#SyntheticGearOil[/url
Its not so much the GL-5 wears out the syncros, its that it is too slippery and makes them spin/slip longer before matching speed and allowing the gear shift to happen. So a good GL-4 oil will provide faster, crisper shifts. A good synthetic GL-4 oil will also help with low temperature shifting performance.
Old Oct 23, 2004 | 02:46 PM
TACOMANATOR's Avatar
I just changed out mine with the MT-90 and removed the stock spring that was squeking. Feels much better now.
smthwsn357
May 1, 2024 07:28 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Eggslinger
Jun 8, 2019 03:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
