Gears?
Old Apr 8, 2008 | 04:10 AM
deines97runnah's Avatar
Gears?
OK, I don't have alot of time to search (although i have tried both online and on here, possibly lacking the skills?) I am getting ready to buy 33" and want to re-gear. I think 4.88 will do from what i have gathered so far. Were do i get these "gears" you speak of? Also looking at having someone that is knowledgeable install them. What am i looking at in labor cost? Just a ballpark figure. Thanks
Old Apr 8, 2008 | 04:22 AM
camo31_10.50's Avatar
go to 4wheelparts.com...they seem to be pretty cheap..called genuine gear..and another brand..(dont know the name)...im sure others will chime in with places that are better and/or cheaper...good luck!
Old Apr 8, 2008 | 04:36 AM
Thanks. 7.5" Right?
Old Apr 8, 2008 | 05:45 AM
toy_tek's Avatar
buy here: http://www.justdifferentials.com/
front: 7.5"
rear: 8"
Old Apr 8, 2008 | 05:51 AM
dirtoyboy's Avatar
Stay the hell away from Genuine Gear....
I usually recommend Precision Gear brand and find a knowledgeable person to set them up. The set up is as important (if not more) than the gear make
Old Apr 8, 2008 | 05:59 AM
pfdaxe's Avatar
Check this thread I started for some info:
https://www.yotatech.com/forums/f2/r...hoenix-138384/
ZUK @ http://www.gearinstalls.com/ did a stellar job and knows his stuff. I would stick with 4:56s if your going to run 33s.
Old Apr 8, 2008 | 06:07 AM
hross14's Avatar
Second that--i am running 35's & 4.88's and the motor spins pretty fast on the highways--33's and 4.88's--you better like driving slow.
You can also buy your gears/thirds pre set-up from marlin crawler, inchworm gear..etc.
Old Apr 8, 2008 | 06:57 AM
crolison's Avatar
i would say 4.56 for 33"s and the v6. Buddy of mine is running 4.88's and 37's
Old Apr 8, 2008 | 08:10 AM
Taro's Avatar
4.88's and 33's with an automatic is fine. Your overdrive is much higher than 5 speed trucks and your rpm won't be that high. .70:1 vs. .83:1
I have 4.56's in my 5spd 4runner. Rpm is similar to an auto with 5.29's in overdrive.
And don't get genuine gear. Almost anything else is better.
Old Apr 8, 2008 | 09:55 AM
Rock Slide's Avatar
Precision gear all the way.
IMO, go with 4.56s & 33's if you do a lot of hwy/high speed driving. Otherwise, go 4.88s.
Old Apr 8, 2008 | 10:29 AM
Processing all infomation. You guys rock.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
