Gear Ratio
Old Sep 10, 2009 | 03:11 PM
bgmac's Avatar
Gear Ratio
Ok, I found this link! http://www.sonoransteel.com/Toyota_axle_codes.html
But its still kinda confusing. My model is #VZN185L-GKPZKA
Now it gives you two options..one with 4.10 & 4.30 w/265/70/16. So if my 4Runner comes with 265/70/16..I have 4.30?
Old Sep 10, 2009 | 06:47 PM
Shubey's Avatar
There is an axle code on the door jamb vin sticker.at the bottom you should see A/TM. The first 4 Letters & numbers are your axle code. A03A for example.If you get that code you can get your stock axle ratio .What part of PA are from?
Shubey
Old Sep 10, 2009 | 07:03 PM
bgmac's Avatar
Im from williamsport. Ok, A03A is my axle code , so whats the ratio?
Old Sep 10, 2009 | 07:29 PM
toyota4x4907's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=274535
4.10s
I suggest bookmarking this page
Old Sep 10, 2009 | 07:30 PM
Shubey's Avatar
Should be a 4.10.I'd have to check my notes at work tomorrow to be sure.
Shubey
Old Sep 10, 2009 | 07:31 PM
bgmac's Avatar
Ya, 4.10 it is....http://www.brian894x4.com/Gearratiosanddiffs.html
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
