Gauge light color change
Old Dec 8, 2004 | 07:12 PM
  #41
Flamedx4's Avatar
Originally Posted by bradym239
. . .a lot more than I need to get flamed for asking for information in a forum meant to supply information to those in need.
Didn't mean to hurt your feelings - and for the record that remark wasn't anything NEAR a flaming... Even the ribbing the guy got who wanted a writeup on changing a tire didn't come near to flaming. Always assume people are being friendly and joking with you, it makes life easier.
Old Dec 8, 2004 | 07:14 PM
  #42
P. Bauer's Avatar
SuperBrightLeds.com
for all LED needs.
Old Dec 9, 2004 | 03:49 AM
  #43
Wild_Bill's Avatar
Originally Posted by 2001Millrunner
Changing gauge lights are easy. I've tried to do the LEDswap and bought lights from superbrightleds.com-failed, LEDs(even inverted ones) dont produce even light pattern to light up the dash, LEDs project lights mostly forward not to the side, mine looked like crap, so I gave up. I'm really interested in pics.
Use frosted LED's, it's the only way to go.
Ok everybody now...oooohh, ahhhhhhh
Old Dec 9, 2004 | 05:37 AM
  #44
keisur's Avatar
See, this is why you should follow Bill's method if you have the time. His is a 5speed too, so it is possible with our manual tranny's. and it looks good too. I wish I had the time. I have the whole week before christmas off so maybe I'll try it then.
Old Dec 9, 2004 | 08:07 AM
  #45
bradym239's Avatar
Yeah, sure. Whatever makes you happy, dude.
Old Dec 9, 2004 | 08:08 AM
  #46
2001Millrunner's Avatar
do you frost them yourself or get one that's frosted? I might tackle this again.
Old Dec 9, 2004 | 09:20 AM
  #47
WT's Avatar
WT
Buy them frosted... I just got 100 Pack from Ebay last week.. I changed the bulbs in my boost gauge to the frosted bLue LED's, The Pic in the post wasn't to great I'l try to get a better one this weekend.
https://www.yotatech.com/forums/show...light=blue+led
Old Dec 9, 2004 | 09:23 AM
  #48
Wild_Bill's Avatar
Do them yourself, I've found after much experimentation that cream cheese works the best. Plus you get the satisfaction of doing the job and having a great result, not too mention a great tasting light bulb when you're done.
Old Dec 9, 2004 | 09:48 AM
  #49
Bigkahuna808's Avatar
how did you replace the turn signal bulbs. I did mine in Blue LED 194s I got from work. But the smaller bulbs in the cluster the 74s I could not get.
Old Dec 9, 2004 | 10:00 AM
  #50
WT's Avatar
WT
:pat:
Should of done it this way... MMmmm It smells so good I bet
Old Dec 9, 2004 | 10:16 AM
  #51
Old Dec 9, 2004 | 11:52 AM
  #52
Flamedx4's Avatar
Fingernail polish works great, and you have a wide choice of colors...
Old Dec 9, 2004 | 11:58 AM
  #53
Flamedx4's Avatar
Here's write up that shows removing the gauge cluster. http://www.4runners.org/articles/wfg/
Only instead of installing a white face, just change out the bulbs.
Old Dec 9, 2004 | 12:37 PM
  #54
keisur's Avatar
to ask a rather old question. Has anyone frinally come out with black faced reverse indiglo gauges panels for the 3rd gen MANUAL tranny?
Old Dec 9, 2004 | 12:46 PM
  #55
keisur's Avatar
speedhut's selling leds now
Old Dec 9, 2004 | 12:52 PM
  #56
dibble9012's Avatar
I was thinking of replacing my instrument panel lights with blue LED's. Does it really look good, lol, does it get old after a while, looks nice in the pictures. Also, how do you replace the AUTO lights on the window switches. How about the ignition light, and the cig lighter light, ashtray. Is it possible somehow to change the color of the stock stereo screen? Do LED's work ok with the dash dimmer? Thanks
Old Dec 9, 2004 | 12:57 PM
  #57
Wild_Bill's Avatar
Same way I did everything else. Just soldered the LED's right to the flex circuit on the back of the cluster. Also took out the green fild under the arrows and put in blue film with flat white overlay, gives it a gray look when off, matches the grey (silver) gauge faces.
Old Dec 9, 2004 | 01:33 PM
  #58
keisur's Avatar
Originally Posted by dibble9012
Ihow do you replace the AUTO lights on the window switches. How about the ignition light, and the cig lighter light, ashtray.
http://bellsouthpwp.net/o/l/olaverty...h/bluedash.htm
Old Dec 9, 2004 | 04:16 PM
  #59
Jason B's Avatar
Access Denied. Bandwidth limit exceeded.
Old Dec 9, 2004 | 07:22 PM
  #60
Henryv's Avatar
Butnut has a writeup on doing blue turn signals. Basically you just take out the cluster, take off the plastic coverings, and replace the green plastic slugs with some blue cutouts (ie from a blue transparant folder). Also, I found it looked better with some blue or superwhite bulbs. Otherwise you need thick layers of cutouts to get a good color, but I think that would also diminish the light. The inverted lens led's spreads the light in my cluster really well. In mine, it looks pretty uniform. The 74's behind the a/c panel is anohther story. THere is only 2 bulbs behind it and does not work too well with straight projection leds. So I put in flat tipped led bulbs and since they dont come frosted, I sanded the tip a bit and its pretty decent looking now. Not perfect but pretty close.
