Gauge and dash backlighting
Old Feb 2, 2011 | 11:13 PM
  #421
OJ Simpson 4Runner's Avatar
no need to remove those, just a bulb replace/install.
http://cgi.ebay.com/ebaymotors/Xenon...Q5fAccessories
something like that
Old Feb 3, 2011 | 03:55 AM
  #422
maxspeed96ct's Avatar
something like that
I wish it was that easy. The 99 gauges have 24 bulbs, there isn't many cool options like that out there. The ones that are available are to wide to fit through the holes in the back of the cluster..
Old Feb 7, 2011 | 07:32 AM
  #423
Can someone help me out with finding led dome lights for my 98??? part numbers would be highly appreciated, im going through the ebay route
Old Feb 15, 2011 | 08:11 PM
  #424
So one of my hvac lights burned out. I also read that many others have the same problem from AUTOLUMINATION.com so I suggest you all AVOID buying from them.
Old Feb 16, 2011 | 06:38 AM
  #425
pfdaxe's Avatar
Their bulbs are good. I had an issue last summer with a couple of them blowing out too quick, but they resolved the issues. I would and still use them.
Old Feb 16, 2011 | 12:01 PM
  #426
Its hit or miss with LEDS from my experience , I had some from superbrightleds burn out on me after just 6 months. And I have some ebay leds that I got dirt cheap that still work great after over a year...
Its not a bad idea to order a extra or two..
Old Feb 16, 2011 | 12:05 PM
  #427
did you have to ship back the defective ones at your own cost ? They had poor communication prior to me ordering it. and then I ordered them and from superbrightleds and even though I ordered from autolumination 2 weeks before i did from superbrightleds, autolumination came in 4 1/2 weeks later after superbrights came in. shipping was the same.
Old Feb 16, 2011 | 12:16 PM
  #428
pfdaxe's Avatar
Probably. It was last year. I don't know anyone that pays for return shipping. They are local for me so I receive in a day or two. I also use V-LEDS.COM. I receive their parts in about three days. Your in Canada so the shipping is a headache with customs. I won't order from your great country because of the shipping. I have tried several times and it takes several weeks. I receive from Asia quicker....no joke.
Old Mar 2, 2011 | 06:40 PM
  #429
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
I ordered dyed incandescent bulbs to give a factory look. Not bright and vivid like leds. I am stumped as to why I have hot spots in my climate control. I may have to try to get back in there and seat the bulbs a little bit better. Though it is not as bad in person as it looks on the camera.
BTW I ordered from autoillumination on Sunday and received the product today. Although I did pay the extra for the priority shipping because of the horror stories I have heard about slow shipping times from them.
Blulbs...
And 2 bad pictures...
Old Mar 2, 2011 | 11:29 PM
  #430
Blulbs...
how did u get ur HVAC to fade from blue to white like that?!
Also I just convered my HVAC from tri-leds to blue 3point smt's, the kind that are on a green chip and cover nearly 360 around. The problem is that one already burnt out!!! the other is starting to flicker and im getting very mad, I did what i could and put the blue working led on the left side for fan speed and put white on the vent control, it actually looks really good.
Old Mar 3, 2011 | 04:52 PM
  #431
toylocost's Avatar
The white fade is because the bulbs are cheap. The tips of the bulbs arent dyed as heavily as the the sides and the white points are where the bulbs are located behind the diffuser panel or whatever you wanna call it.
Old Mar 3, 2011 | 09:38 PM
  #432
jbudhram015's Avatar
Update
I got this all done, got my lights from autolumination.com. Kinda felt like the bulbs were expensive for how simple they ended up being. Also, heavy modification to get anything to fit, and by modification I mean grinding the piss out of all the bases on the bulbs. Everything that gets replaced is a tiny bulb with a condom that is half the size of the replacement LED you get from the website. I had to separate all the bulbs from the bases and reduce the bases to almost nothing then reassemble and install. The three way LEDs do reduce the hot spots in the HVAC based on some of the pics I saw. I don't really want to post my shopping list because I wouldn't recommend what I purchased because it was so much work to make it all fit. It does look good though. Pretty happy with the outcome, I didn't have a glove box or ask tray light before so, win. Here's some pics.... The hotspots are worse in the pics than they are in person.
Attached Thumbnails Gauge and dash backlighting-img_3161.jpg   Gauge and dash backlighting-img_3164.jpg   Gauge and dash backlighting-img_3163.jpg
  #433
Mo pics....
Attached Thumbnails Gauge and dash backlighting-img_3160.jpg   Gauge and dash backlighting-img_3162.jpg
Old Mar 4, 2011 | 12:42 AM
  #434
son209's Avatar
If you want to get rid of the green on the A/C button you can take the face of the button off and carefully scratch the green tint off of it. I put it up against a light and only scratch green off where it said A/C. And put in a matching LED.
Old Mar 7, 2011 | 05:26 AM
  #435
pfdaxe's Avatar
Which bulbs did you get? I never had to mod or trim or grind any bases for the bulbs I got from there. Sounds like you got the bigger base ones...
Old May 27, 2011 | 01:44 PM
  #436
quicksilvr's Avatar
Has anyone tried to fit these honkers in the gauge display? I'm replacing my sister's '97, and I think these will fit, but they are pretty big. I can't picture how much clearance there is in there...
Old Jun 16, 2011 | 06:30 AM
  #437
Stive2699's Avatar
I do not think those will fit.
I got these http://www.speedhut.com/custom_gauge...number-430.htm
I Do not see any '97 model on there though but I am sure someone has posted that year's gauges somewhere in this thread.
I am replacing my brake lights with LED's because one of my parking lights burnt out the other day so I figure ill upgrade a couple more lights. Still not enough cash to upgrade all to LED's. Anyways, my question is for the brake lights. I do not no whether to get the white led's or the red led's. The cover plate is of course red. Just do not know of the whites would be to bright or if the red's wouldn't be bright enough.
Also another small question. My steering wheel leather is falling apart on top mostly. Has anyone found any replacements for cheap? All I can find now are leather covers that avrg. $50. I could have swore one time I was looking replacement wheels up and I was finding some for around $40 for a new wheel not just a cover. It's getting to the point now were I would really like to replace it.
Thanks all!
Old Jun 20, 2011 | 12:46 PM
  #438
Tugger01's Avatar
how hard is it to change the lights in the a/c control on a 86 pickup i took the dash off and looked down there and it looks like a bitch to get everything off and even think about getting back on. I did red on my dash lights look pretty sweet.
Old Jun 21, 2011 | 04:14 PM
  #439
offset442's Avatar
I switched all of mine from green gel bulbs to red LEDs , and changed to gauge cluster to dancing flames electro-luminescent audio activated printed film over lays it looks bad ass check out my avatar pic and my photo album. also changed all of the lamps in the cluster with the same red LED's and an orange one for the CEL
I couldn't strand the green as it was too bright and blue is just as much an offender for light pollution while driving around at night
Old Aug 19, 2011 | 02:57 PM
  #440
tylersphile's Avatar
Blue-tint Clock Conversion
I decided to start the conversion with the hardest part. Took about 2 hours along with soldering the pins (springs lost connection).
Basically, I dremelled off the edge of the OEM clock cover to remove the tinted "tan" colored plastic faceplate from the sides. I wanted to retain the surrounding piece for easy re-mounting. Then flattened the cut edge with a file to create a good bonding surface for the new plexiglass piece.
As for the plexi, I used 1/16th inch and cut to shape with jigsaw. Then cut the button holes with a small dremel bit. Cut 3 pieces of blue "spotlight color film" (purchased from the local pro-music/lighting store), slightly smaller than the plexi to allow adhesion to each when gluing to the OEM "now-faceless" plastic trim piece. Cut the button holes in the blue tint, then traced the edge of the with acrylic cement and put the two together.
Snaps right back into place!
Installed:
Tools and supplies:
Before Install:
