Gapping Spark Pluggs
Old Oct 11, 2003 | 06:00 AM
heholaday's Avatar
Question Gapping Spark Pluggs
Just ordered plugs for my 99 runner from Toyota. Do these need to be gapped or are they pre-gapped. If so, how much?
Old Dec 16, 2003 | 06:27 AM
4RunnerFever's Avatar
This may be an obvious question, but I would also like a solid answer as I'm getting ready to do the bulk of the 60K tune myself.
Thanks to all who respond!!
Old Dec 16, 2003 | 06:30 AM
TDiddy's Avatar
Don't trust the "pre-gap". The specs should be in the owner's manual, don't know them off the top of my head.
Old Dec 16, 2003 | 06:47 AM
runnerboy97's Avatar
The book says .045 inches. If they are dual electode plugs, just look to see that all the plugs are real close to the same and you will be fine. Thats what i did about 1000 miles ago, and no problems, it runs great.
Old Dec 16, 2003 | 06:53 AM
MTL_4runner's Avatar
The dual electrode plugs are difficult to gap and should be fine right out of the box. Do check (as was mentioned) so see that they were not damaged in handling BEFORE you install them. I think there have been a few cases where a bent electrode on an installed plug was causing a miss on the engine. A simple visual inspection of all the plugs will quick spot any outliers and save you some serious diagnostic headaches.
Old Dec 16, 2003 | 07:04 AM
Nam's Avatar
Nam
Generally you don't need to re-gap them since they are specifically design for your engine...well like someone mentioned, a visual inspection may do the job.
Good luck,
Nam
Old Dec 16, 2003 | 07:10 AM
TDiddy's Avatar
https://www.yotatech.com/forums/show...&highlight=gap
Old Dec 16, 2003 | 07:28 AM
With the twin electrode plugs - how do you check the gap. I have a difficult time getting the usual gapping device to work. What you you guys using to check the proper gap??
Inquiring minds want to know!!!!
Andrew
Old Dec 16, 2003 | 08:28 AM
Needs to be done with a wire type guage.
The ramp style is totally useless.
zytra
Jan 24, 2019 03:16 PM
Kamaloha
Oct 16, 2015 05:13 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
Rcbc92
Sep 26, 2015 03:00 PM
