Fuel Pump Upgrade Results
Old Sep 7, 2003 | 09:41 AM
Nocron's Avatar
Yesterday my brother in law installed an upgraded Walbro fuel pump in my 98' S/C 4runner based on the feedback I received on this forum. He has been a Toyota tech for about ten years and we were able to use the dealership facilities for the install. Before the install, the 4runner would stumble at higher rpms or when it was really working hard (i.e. trying to maintain speed up a large hill or under hard acceleration.) After the install, the stumble was gone and the S/C seems to pull throughout the rpm band. Unfortunately, I do not have an EGT meter or fuel/air meter but the car is running much better.
We also cleaned the throttle body and maf, and together with the fuel pump upgrade, the idle is much smoother.
Old Sep 7, 2003 | 12:49 PM
MTL_4runner's Avatar
Nice...great to hear success stories!
Old Sep 7, 2003 | 01:04 PM
Vato Loco's Avatar
I think we need some ET times? Glad to hear everything went great!
Old Sep 7, 2003 | 01:33 PM
cstary's Avatar
Re: Fuel Pump Upgrade Results
sounds like you needed a MAF and TB cleaning. the fuel pump should just have provided a little more power at the top end, not cure any stumbles, especially at idle. i mention this because anyone who's having stumbling problems shouldn't consider a larger fuel pump as a fix . . . . but glad to hear the truck's running better!
creed
Old Sep 7, 2003 | 02:46 PM
Nocron's Avatar
In hindsight, it would have been helpful to do the TB and MAF cleaning after determining the impact, if any, of the fuel pump upgrade....in order to isolate the improvement. My intention with the fuel pump upgrade was to hopefully reduce EGT and to begin the fuel system upgrade process. Next step - save up for the injector/injector controller upgrade.
We also installed Bilstein shock/struts and the handling definetely improved as a result.
Old Sep 7, 2003 | 02:54 PM
cstary's Avatar
sounds like a productive weekend! how'd you like getting those rear shocks off?
creed
Old Sep 7, 2003 | 03:44 PM
Nocron's Avatar
Sounds like you are speaking from experience. At first glance, I thought the rear shocks would be straight forward. It actually took longer to do the rear shocks than the front. The fuel pump ended up being the biggest pain in the ass, and this was with the benefit of a vehicle lift and transmission lifter we used to position and raise/lower the tank.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
