Fuel Cut Off Switch
Old Jul 19, 2003 | 10:13 PM
lbb-1's Avatar
Fuel Cut Off Switch
Has anyone done this?
Does anyone have a write up for a 2nd Gen?
Thanks
Old Jul 20, 2003 | 12:42 AM
anondrao's Avatar
for the fuel pump?
the wires for the fuel pump are located under the drivers side seat and exit the body at the backseat floorboard. i haven't traced them further, but i have pictures of all the wiring under the seats.
i relocated the rear window up/down switch to my dash next to the clutch start cancel switch. the wires for that run parallel to the fuel pump, guage, and antilock sensor.
Old Jul 20, 2003 | 12:50 AM
lbb-1's Avatar
Pictures
Cool man
Could you post the wire pics?
That would help out alot.
thanks
Old Jul 20, 2003 | 12:58 AM
anondrao's Avatar
yup, and i'll also post the haynes wiring diagram. :: but not tonight. i will do it soon.
the diagram will be most helpful.
also, you could go to an auto parts place and look at the haynes or chilton books for the wiring diagrams in the back.
what a life saver. i relocated the rear window switch without having a multimeter.
quite helpful.
~andon
Old Jul 20, 2003 | 05:39 AM
Corey's Avatar
Co-Founder/Administrator
You might try this online 2nd gen factory manual also.
It's packed with some good info.
Old Jul 20, 2003 | 07:23 AM
UKMyers's Avatar
Just out of curiosity why do you want the switch.. security measure of some sort I am guessing?
Old Jul 20, 2003 | 11:52 AM
lbb-1's Avatar
Security
Yeah,
I'm in Hawaii now put moving to California, so along with the Autolock, I'll do a fuel cut off switch.
better save than sorry ( I'm just paranoind) plus I'ts an excuse to work on the 4runner.
Thanks Guys
later
Old Jul 20, 2003 | 12:24 PM
Mad Chemist's Avatar
I hear ya, I've been thinking about doing the same thing. Initially, I thought of running a switch behind the gas door, but then thought, hmmm, electric switch, gasoline, might be dangerous! I'd like to have a switch somewhere outside the vehicle that will be less obvious to a thief looking for a cutoff switch.
Old Jul 20, 2003 | 02:31 PM
lbb-1's Avatar
Maybe this switch
http://www.jcwhitney.com/item.jhtml?ITEMID=4433&BQ=null
Old Jul 20, 2003 | 03:09 PM
lbb-1's Avatar
Found thread
https://www.yotatech.com/forums/show...t=fuel+cut+off
Looking at my haynes looks like blue wire for 95 4runner?
(does that sounD right?)
Can't seem to find what AMPS it's rated at for a switch/relay/fuse selection??.
later
Old Jul 20, 2003 | 09:38 PM
lbb-1's Avatar
I'm no electrician
Picked up a Rocker swith from radio Shack (says for automobile)
Rated 25A at 12VDC
Found another in my garage (Toggle)
20AMP 125 VAC/CA
10AMP 277 VAC/CA
3/4 HP/CV 125-250 VAC/CA
Could some one translate this into english??
Should, I use the rocker or toggle?
thanks
Old Jul 21, 2003 | 12:11 AM
anondrao's Avatar
Rocker Switch :
25A at 12VDC
25 Amps at 12 Volts Direct Current...
DC is what a battery creates.
20AMP 125 VAC/CA
--125 Volts Alternating Current
10AMP 277 VAC/CA
-- i don't know about this one
as far as a switch goes, if it connects the two points, i can't imagine it would make that big of a difference.
a tiny ass switch will not be able to handle much current and will overheat and fuse probably.
AC to DC
AC current, or Amps is not the same as DC Amps... at the same voltage.
switch style is simply preference. i like rocker switches for my lights, and toggle switches for my cut-off switches... that's just my preference.
i would use the DC rated switches to be on the safe side...
but i'm sure one of the techie guru's will correct me, so we'll see.
Old Jul 21, 2003 | 09:35 AM
lbb-1's Avatar
Switch
Thanks
I'll go with the 25 Amp Rocker Then.
later
Old Jul 21, 2003 | 01:31 PM
runnerboy97's Avatar
does anyone know what wire it is on a 3rd gen. cause i think a fuel pump cut off is a cool idea. any help would be great.
Old Jul 21, 2003 | 01:34 PM
Hey Runnerboy, I'm trying to do one myself, so whoever finds out first has to post the details!
Old Jul 21, 2003 | 01:39 PM
alrighty then, the race is on.
pyramid
Jul 30, 2015 10:05 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
crashburnoveride
Jul 10, 2015 06:39 AM
