Front Wheels Will Not Come Off!!!
Old Jan 15, 2004 | 07:44 PM
cubuff4runner's Avatar
I have had buddies that worked at tire places. Although it may seem like some places do an alright job, many are not especially when it comes to balancing.
Old Jan 15, 2004 | 08:03 PM
Brendan's Avatar
Originally posted by 4RUNR
Loosen lugs by a few mm. drive 10mph then brake. That would apply a bit more force than a 10lb sledge.
I've always thought what is the point of people carrying spare tires.
#1) Most factory tire irons would break if the lugs were put on by an impact wrench yielding mechanic.
#2) Most would have same problem that COSTCO had.
I bet we would save millions barrels of oil each day by taking out the weight of useless spares
I don't understand. Why are spare tires a waste of space? What do you do if you get a flat while your in the middle of nowhere?
Old Jan 16, 2004 | 03:58 AM
Mossback74's Avatar
I think he means you wont be able to get the flat off.
I've always used a bit of anti-seize to make things easier "The next time"
Old Jan 16, 2004 | 05:03 AM
4RUNR's Avatar
Guest
What good will a spare be if you can't take off the lug nuts or separate the wheel from the hub Unless of course AAA guy comes with a 20lb sledge
  #25
Los Gatos?'s Avatar
I had this problem before, I used a hammer (on the tire sidewall) to knock the suckers lose. Yes I know that's not good for the sidewall, but rockcrawling is probably worse, and I'm upgrading to 32x12.50 soon I hope
Old Jan 16, 2004 | 05:09 AM
  #26
MTL_4runner's Avatar
Put the truck up on jackstands and give it a good kick outwards on the inside rim of the wheel.
Old Jan 19, 2004 | 10:44 AM
  #27
Smile
Thanks for all the ideas I tried the PB blaster and tried jacking it up and kicking like hell but it still wouldnt budge. Took Mikes advice and took it to Midas for a brake inspection and they got them off. And just as I expected I need brakes also I did finally get my tires put on and so far so good. I was thinking of selling the Runner this spring and getting a 99 Runner but now I might just keep it for another year.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1994toyota
Jul 17, 2015 03:03 AM
skoti89
Jul 6, 2015 07:45 PM
