Front End Vibe
Old Aug 14, 2006 | 08:01 AM
slemay6's Avatar
Front End Vibe
Just did a search because I am noticing a vibe in my 4runners front end. Lets just say the search was depressing.I want to start a new thread for everybody that has vibrations in their 4runner.If you solved your vibe problem please explain how.THKS
Old Aug 14, 2006 | 08:06 AM
PoleVaulter95's Avatar
could your tires be out of balance? mud on your wheels? Steering Damper completely toast?
Old Aug 14, 2006 | 08:08 AM
slemay6's Avatar
No mud,just had the tires balanced.Have not checked the steering dampener.
Old Aug 14, 2006 | 01:04 PM
Gerdo's Avatar
A 01 4Runner does not have a steering damper. I've been wondering if you could add one or two and would they help?
Old Aug 14, 2006 | 01:16 PM
Firefightertaco's Avatar
Check your lug nuts to make sure they are tourqed right, may have lost a wheel weight too.
Old Aug 14, 2006 | 02:34 PM
BajaRunner's Avatar
Under acceleration or braking? Cruising?
You have any lift?
Could be rotors under braking, and could be the driveshaft needing some lubing under accerlation.
Old Aug 14, 2006 | 06:40 PM
Tanto's Avatar
If your lower control arms are loose (even slightly) you may notice a slight vibe. Although that would also mean your steering will feel weird.
Old Aug 14, 2006 | 06:47 PM
gregbreakseverything's Avatar
My rotors are toast, easy fix, just need to find money and time. Nothing worse than a shaky truck.
Old Sep 7, 2006 | 06:18 PM
hause64oz's Avatar
I have a pretty bad vibration when I am accelerating past 50 mph... its worst between 55 and 70, tones down a little at 74 but gets noisier up to 80.... when I let off it smooths out..... under 50 it isnt very bad.... sounds like the U joint problem most people have talked about... but any chance the transmission is failing? 2001 4runner 2 wd - 109000 miles... im going to look under it tomorrow morning but I thought Id throw this out so I can put my worries to sleep.....
Old Sep 7, 2006 | 06:26 PM
KyleT's Avatar
i had a vibration... so i put new upper and lower control arm bushings, upper and lower ball joints, steering rack, rack bushings endlinks, springs, struts and new tires. then had it aligned. vibration is gone.
Old Sep 7, 2006 | 08:43 PM
az984Runner's Avatar
I am having the exact same symptoms as everyone is describing. I had a brakes shop look at it today and they want to machine the rotors, new pads, and adjust the rear brakes for $275 and replace my bushings, steering rack, and everything else that goes with that for $1200 I found a recycled (meaning removed from a wreck) steering rack for $100 online. Is the steering rack an easy install KyleT? I'm sure for only $100 plus other parts it will be worth any trouble I may run into.
Old Sep 13, 2006 | 02:47 PM
jfond's Avatar
I had a vibration issue - had the tires rebalanced - didn't help. Checked several other things - found no issue - went back to the tire shop, and they did a "Ride Match Test" and found out that 2 of the tires were bad - replaced them and the issue was resolved.
Old Sep 15, 2006 | 04:32 AM
KyleT's Avatar
i was hating life doing that part of the job. i also replaced the bushings with the energy suspension poly rack bushings as the stock ones wear out pretty fast. the center vertical bolt is the toughest part. couod not get it back lined up. ended up breaking the welded nut off of the frame and throughbolting it with another nut and bolt.
Old Sep 15, 2006 | 05:21 AM
mehret's Avatar
Assuming you checked the tires, brakes, etc, my next suggestion would be to drop the driveshaft and check the u-joints to make sure they arent binding.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
