Front Driveshaft Angle....too high?
Old Jul 16, 2005 | 06:10 PM
4RocRunner92's Avatar
Does anyone think my angle is too steep?
This is that other question I had on my Driving in 4WD thread.
Is it possible to rotate a front end? It looks like it needs to a little bit. Cause see look at where the U-joint is to the pumpkin. It looks like I need to turn the front diff upwards a little bit. Check out these pictures. I hope someone can understand what I'm trying to say.
Old Jul 16, 2005 | 06:46 PM
BruceTS's Avatar
The angle on the drive shaft is a bit much, to correct the problem you need to rotate the axle housing to be more inline with the shaft. In doing this the caster will be off and need to be corrected, otherwise you'll have death wobble..... To rotate the knuckles requires quite a bit of work, cutting the ends and turning them. Another alternative is to replace the axle housing with one of Front Ranges Diamond housings.
You can always just run it the way it is, I've seen many do it, usually they pull the shaft out of the splines during full droop.
Old Jul 16, 2005 | 08:34 PM
LOL
Does Front Range have a website? How costly would this be? I definately need to correct it soon.
Old Jul 16, 2005 | 11:17 PM
superjoe83's Avatar
another option would be to get a high pinion, or a dual t-case, either would help the problem, but wouldn't be nice on the wallet
Old Jul 16, 2005 | 11:23 PM
yotaman's Avatar
Another option is to drop your lift some. Lower springs, a BFH (noobs, BFH = Big ˟˟˟˟˟˟ Hammer) and some fender trimming will probably do wonders. Just a thought.
kazuya2416
Apr 5, 2024 02:17 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Nickdigg
Jul 7, 2015 06:04 AM
