Front Differential Breather Hose
Old Sep 23, 2007 | 08:46 PM
hross14's Avatar
OK--not a new question.......but a pain the arse situation.
Noticed that i was leaking gear oil from the front differential. Did a little investigating and found that a little PITA rubber hose that connects the differential elbow (metal) to the metal hose that goes to the diff breather was off--sheets- Tried like an SOB to put it back on but i just couldnt do it. any ever had this happen? Suggestions, tips. Friggin Help
Old Sep 24, 2007 | 06:53 AM
hross14's Avatar
bump the post--please help--drained the diff and it had a decent amount of water in it. Cant have this happen again......
Old Sep 24, 2007 | 07:17 AM
toy_tek's Avatar
I just installed my front diff, and had to reconnect that breather line. You can access it from the front side with the skid removed. Get some long angled needle nose pliers if you need. Looks worse than it is.
If you need to you can drop the diff down a bit by removing the two front mounting bolts on the two arms. This will get you a bit more clearance to get your hand up in there. Torque the bolts to 100ft-lb when you're done.
Old Sep 24, 2007 | 07:46 AM
hross14's Avatar
thanks--tried all that and still couldnt get my hands in there. I guess i will just remove the engine and connect it LOL. No--but i think raising it might be an option or just removing the metal hose altogether and just going with a rubber hose.
Old Sep 24, 2007 | 08:01 AM
Ringmaster's Avatar
I just used 5/16 fuel line hose on mine. Ran it up by the fuse/breaker box behind the battery,
Old Dec 10, 2007 | 07:54 PM
Gold_Digger's Avatar
Does anyone know if 3rd Generation differntial breather unions will fit 2nd gens front differential...This may be the answer if it fits. Part is only a few bucks and is a right ingle union.
Ladythump
22
Nov 9, 2015 08:53 AM
jerusry
Oct 19, 2015 05:28 PM
scottyg486
Jul 19, 2015 05:34 PM
jjrbus
Jul 19, 2015 02:06 PM
AaronM
Jul 8, 2015 07:15 PM
