Front Brake Conversion
Old Feb 25, 2016 | 10:49 AM
Ifoundyoda's Avatar
How bout it guys
I have been seeing and reading about guys putting Tundra front brakes on their 3rd gen 4runners. My front brakes are crap right now and I am going in for new tires in the morning. Are the Tundra rotors & calipers etc. simply interchangeable?
Thank you in advance!
TC
Old Feb 25, 2016 | 12:58 PM
elnip's Avatar
Yes they are
Old Feb 25, 2016 | 02:00 PM
Ifoundyoda's Avatar
Are the calipers reusable or do they have to be replaced with Tundra calipers?
Ifoundyoda's Avatar
And what year Tundra setup did you use?
Old Feb 25, 2016 | 02:03 PM
elnip's Avatar
Go with the W231 Tundra calipers vs the 199 since they are a little bigger and you will need the tundra rotors and pads.
Mine came off of a 06.
Old Feb 25, 2016 | 02:09 PM
Ifoundyoda's Avatar
Do the W231 Calipers use the 5.3" pads?
Old Feb 26, 2016 | 04:45 AM
elnip's Avatar
I can't recall. I just bought new ones.
Old Feb 29, 2016 | 03:49 AM
aowRS's Avatar
Here is my installation: Tundra brakes
Andreas
Old Mar 1, 2016 | 01:04 PM
Ritzy4Runner's Avatar
I did the conversion on my 98 here is the write-up and I believe I did updates on them, including replacing both rotors and pads with those hybrid pads. I used the 199mm as mine came off a 2001 Tundra, but which ever way you go it will make a serious difference and you will be glad you did. If you note in my write-up the only modification I had to do was to the dust shields and that was only filing away a very small amount, 10 minutes per wheel max. Give a look/read
https://www.yotatech.com/forums/f2/0...runner-146160/
Old Mar 4, 2016 | 07:07 AM
Malcolm99's Avatar
Don't forget to make sure the calipers fit inside your rim, 96-97 rims won't work with Tundra calipers.
Old Jun 22, 2016 | 11:05 AM
NEKExplorer's Avatar
Even the 199mm won't fit on 97 rims? If they are 16" rims?
Old Jun 23, 2016 | 06:13 AM
elnip's Avatar
If they are 16" I don't see why not..
Old Jun 25, 2016 | 09:33 PM
kapeket's Avatar
Suggestion for a 92? I know I've got to do the rear drum conversion at some point but will the Tundra front brake parts work on a 92? Running 2016 17" rims and tires so I'll have room.
Old Jun 26, 2016 | 12:20 AM
wyoming9's Avatar
I am still waiting to see some real numbers !!!
If I am really bored one day I will sit down and crunch the numbers.
Sure WOW it makes a big difference well replacing worn out brakes with new brake parts will make a difference.
Two owners later it gets real interesting when the brake parts you ordered by the year and model don`t fit
I find my truck stops just fine with well maintained brakes .
I like my Drum brakes just fine.
SilentBounty
Mar 22, 2016 10:29 AM
kauaiaxel
Feb 16, 2016 12:37 PM
mct75
Feb 7, 2016 01:32 PM
conehead
Feb 7, 2016 11:30 AM
Snowking
Jan 29, 2016 02:03 PM
