View Poll Results: Do these look good?
Yes
11
78.57%
No
21.43%
Voters: 14. You may not vote on this poll
Fog Light Opinion
Old Jul 26, 2002 | 03:02 AM
HBoss's Avatar
Fog Light Opinion
Just wondering your opinions on the rectangular fog lights mounted on the bottom of the bumper area:
Old Jul 26, 2002 | 03:42 AM
jacksonpt's Avatar
Senior Member
Looks good. I've been thinking about something similar... except I want to retrofit a set of fogs into the factory turn signal location, then rewire my corner lamps as my turn signals. Maybe over the winter when I have more time...
Old Jul 26, 2002 | 03:54 AM
HBoss's Avatar
Now that's a pretty good idea. I was thinking the same thing about reusing the turn signal slots for fogs... Let me know how that turns out. Maybe I'll do the same, with the extra two fogs underneath.
I'm planning to get a grille guard next year, which is why I'm not thinking about mounting fogs in the middle anywhere. It would just be a waste of time as it would be blocked out by the grille guard later.
Old Jul 26, 2002 | 04:07 AM
BTOWN4RUNNER's Avatar
I really like the looks of them. They look almost stock, but then you remember that the stock ones are round, and not rectangular. I think they look pretty cool! :fireman:
Old Jul 26, 2002 | 06:09 AM
jacksonpt's Avatar
Senior Member
Actually, for that year, the factory ones are rectangular.
Old Jul 26, 2002 | 06:39 AM
nrgetic99's Avatar
I looked into that with my '96.
In the end, I custom fabbed some brackets and mounted some Hella's either side of the lisence tag.
However, they were pretty vulnerable.
Many guys use PIAA's cut into the valance as they look very factory . My concern would be cutting a perfect square opening and getting it level. The PIAA's have a trim ring that will cover up any bad cutting but with a hole cutter, you can get a perfect circle.
BTW, the Hella 500's were soooooo much better than my stock fog lights, even with uprgraded bulbs.
David
Old Jul 26, 2002 | 06:51 AM
Sorry, my bad! Thanks for correcting me though!!! :fireman:
Old Jul 26, 2002 | 07:41 AM
HBoss's Avatar
I never even knew they had stock fogs for the '97 model! Damn...I wonder if I can get a factory bumper with holes for the rectangular fogs.
Otherwise I have to find the fogs, do the cutting and conjure up a good bracket to keep them in.
Old Jul 26, 2002 | 07:51 AM
jacksonpt's Avatar
Senior Member
yuppers, they sure do. Here's a pic. It's hard to find a 96-98 with fogs, so I had to resort to ebay, so I'm not sure who's rig this is.
Old Jul 26, 2002 | 08:02 AM
HBoss's Avatar
Ok, I see what you mean. I thought you meant factory ones where the fogs are in the pic I showed above.
They sell those fog lights and you have to cut away the plastic for a nice fit. They're not bad but again, because I'm getting the grille guard next year, it will just block those lights out.
Guess I'm going to cut away at my bottom bumper sometime and get this going. Have the clear corners now and going to get the clear bumpers later on. All the lights in front being clear should look great I think.
Old Jul 26, 2002 | 08:37 AM
SLC Punk's Avatar
I think that the fogs would look good mounted there. I went the easy route and pruchased the fogs off of ebay (Toyota part number, box, instructions, but the actual lights are hella)
Old Aug 26, 2002 | 05:11 PM
Hermes's Avatar
I can't believe Jason B hasn't chimed in on this one.
If I had a pre-99 truck I would follow his lead and get the Performance Products valance. It looks better than factory option and puts the fogs on the outside of the truck - where you want them.
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
nonstop
Jul 24, 2015 06:29 PM
Odin
Jul 15, 2015 09:28 PM
A2theK
Jul 12, 2015 10:46 AM
