Fly Wheel cracked
Old Jun 20, 2003 | 08:57 AM
avaday's Avatar
Fly Wheel cracked
I have a '98 4Runner Ltd. with 72k miles and the flywheel crackked. I caught it before it broke down. What would case this to happen? Has it happened to anyone else? Thanks.
Old Jun 20, 2003 | 09:06 AM
rimpainter.com's Avatar
Can you take some pictures and post them?
Cracking is usually caused by the rapid cooling of a very hot part.
Old Jun 20, 2003 | 09:08 AM
TOR
FLY WHEEL
Haven't seen that many come through the shop but I can get one to your front door for 282.35 including shipping. If you're interested send me an email.
Todd
Old Jun 20, 2003 | 10:54 AM
Is this on an auto tranny vehicle? Seen plenty of flex plates crack on a variety of brands, have not seen a flywheel for a manual tranny crack to best of my memory.
Old Jun 20, 2003 | 10:58 AM
LTD's only came in AUTO form.
Old Jun 20, 2003 | 11:58 AM
Then its a flexplate, not flywheel (unless they came with Allison ATs )
Flexplates tend to crack at crank mounting holes, generally because bolts were not tight and its the weakest point on the flexplate due to a bunch of holes in a small space (swiss cheese effect). But sometimes they crack for no obvious reason at all, bolts were tight and everything fine.
Edited to add- Flexplates are stamped steel whereas flywheels are generally of cast iron except in high performance apps. Stamped steel can crack at flaws and other stress points.
Old Jun 20, 2003 | 12:39 PM
avaday's Avatar
thanks, but anything I may have done to cause this - like start the engine when it was already running, shift from drive to 2 abrubtly (engine braking), spin the tire aggressively in snow or sand, etc? These were some of the reason I came up with.
Old Jun 20, 2003 | 12:52 PM
This is really odd. Do you know the history of the vehicle? Are you the original owner?
I garantee that I put my old 98 Limited Tacoma through as much, if not more than anything you could have thrown at your vehicle. I floored it constantly, burned out in snow, sand, dirt and on pavement. I held gears and bounced off the rev-limiter. You name it, I probably did it. That tranny held up to it all. No problems. This is freaky. A first for me.
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Up&Down
Aug 5, 2015 06:20 AM
A2theK
Jul 12, 2015 10:46 AM
horunner1x
Jul 10, 2015 06:33 AM
