View Poll Results: What Covers Whats Underfoot?
Roll-in Bedliner
3.57%
Nothing
7.14%
Stock Carpet
16
57.14%
Spray In Bedliner
7
25.00%
Other-Give Details
7.14%
Voters: 28. You may not vote on this poll
Floor Covering
Old Apr 8, 2003 | 12:47 PM
Eighty7ToyTruck's Avatar
Floor Covering
Ok, so who has what as floor coverings in their rig?
post your vote
if you have spray in bedliner or roll in, let us know how you like it....
Old Apr 8, 2003 | 01:38 PM
Todd E's Avatar
I've got a layer of Dynamat covering the entire floor, then I put thin foam padding down in the foot wells, then covered it with automotive carpet.
If I had to do it again, I'd use something besides Dynamat. It's too expensive.
I'd probably get some asphalt covering and carpet over that. Probably have the same effect.
I like it alot. I noticed a decent difference in road noise from before and after.
I need to cover the firewall and my doors next.
Todd
Old Apr 8, 2003 | 04:39 PM
Krash's Avatar
Try B-quiet
When I finally fix the leak in my cab and replace the carpet I plan on putting that stuff down. If I remember right its only 80 or 90$ for 50 sqft.
Old Apr 8, 2003 | 05:43 PM
im thinking about doing rhino lining on the floors and losing the carpet... hell the truck isnt all that comfortable anyways....and the carpet will just get ruined even more so who has rhino lining in?
Old Apr 8, 2003 | 06:22 PM
Todd E's Avatar
Originally posted by Krash
Try B-quiet
Yup, I've got B-Quiet on my back wall and the side panels (under the extracab window). Double layer actually.
Does a good job of noise reduction.
Need another roll (some time and some warmer weather) to finish it off.
I still might see what Home Depot has to offer for asphalt coverings though.
Todd
Old Apr 8, 2003 | 06:27 PM
Krash's Avatar
Lemme know what ya find at homedepot, I couldn't ever find anything in there.
Old Apr 8, 2003 | 06:30 PM
Corey's Avatar
Co-Founder/Administrator
Go camo vinyl.
http://accmats.com/
Use a mop to clean clean inside
Old Dec 11, 2004 | 05:32 PM
fiveofeen's Avatar
carpet samples for floor mats $5 for all 4 and they sure are Plush
Old Dec 12, 2004 | 06:53 AM
leebee's Avatar
check the roofing section
hey krash!
home depot should have a self adhesive roofing product that might work. its used as a water barrier along ridgelines, around vents and along the edges to help prevent ice dams from forming and water seeping through the plywood joints. hope this helps.
lee
Old Dec 12, 2004 | 10:36 AM
seaflea's Avatar
Stock rubber matt instead of carpet. I bought it from a guy here on YT. Its thick tough and easy to clean.
Old Dec 12, 2004 | 08:42 PM
914runner's Avatar
I have the stock carpet, but have thought about Rhino Lining it.
Old Dec 13, 2004 | 06:40 AM
lee's Avatar
lee
i selected spray in by accident!
stock carpet here...
rocket
Jan 21, 2016 05:03 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
mr_manny
Jul 31, 2015 10:39 AM
icentropy
Jul 9, 2015 02:12 PM
