Flashing brake light
Old Nov 25, 2003 | 11:00 AM
Toyminator's Avatar
Hey, how's it going? Whenever im crusin around going over speed bumps, a little on the faster side, or going over obstacles i notice that my emergency brake light turns on. It turns on for only a quick second, depending on how bad im jumping around. I checked the brake lever, and its tight, its not loose or anything. Does anyone know what could be causing this?
Old Nov 25, 2003 | 11:03 AM
Cebby's Avatar
Check your brake fluid level. As your pads wear, the level of the fluid in the reservior also drops to push the thinner pads against the caliper/shoes against the drum.
It is likely as simple as topping it off. When was the last time the brakes were checked?
zedex's Avatar
low brake fluid will cause that.
Speedy typers or what.
Old Nov 25, 2003 | 11:58 AM
Jonathan's Avatar
Re: Flashing brake light
Yep, almost positive it's brake fluid. Mine was doing the same thing a few weeks ago and I topped it off and haven't had a problem since.
Old Nov 25, 2003 | 02:30 PM
Toyminator's Avatar
Awite ill check the brake fluid..The brakes havent been changed probably more than 1500 miles...i drove the truck up from texas to minnesota. That would have been the last time. Thank you
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
