FIXED!! Stupid PLASTIC clutch pedal bushing
Old Aug 15, 2006 | 02:13 PM
  #141
Bob_98SR5's Avatar
i recently took off my spring for ch#ts and giggles and one thing i noticed is that the spring tension is not as bad as with the 2nd gen spring i put in. im leaving it off
bob
Old Aug 15, 2006 | 02:22 PM
  #142
heyben's Avatar
Once again I am in debt to the huge knowledgebase here at Yotatech! Squeeking was driving me crazy, and I wasn't looking forward to taking everything apart to replace bushings. This fix was super easy, effective, and I was done before the first beer was finished! Thanks again!
Old Aug 15, 2006 | 02:31 PM
  #143
UNR.Grad's Avatar
After my first "debt" to yotatech, I contributed to it. Don't forget this site isn't free for those who run it...
Old Aug 15, 2006 | 02:57 PM
  #144
heyben's Avatar
UNR.Grad
You make a good point, and I am now a "Contributing Member". Heck, with as much time as I waste on this site when I'm at work, I should have done it a long time ago!
Thanks,
Ben
Old Aug 15, 2006 | 03:16 PM
  #145
jwbehm's Avatar
I will probably be doing this soon, i have one creaky ass clutch!
Old Aug 16, 2006 | 07:08 AM
  #146
uberhahn's Avatar
I did this too. Am noticing throwout bearing sqeak now. Is it possible that the new spring could be causing too much "up" pressure??
Old Aug 16, 2006 | 09:19 AM
  #147
ilikesoup's Avatar
It's not likely... and I'd say impossible if I was a clutch expert. The extra up pressure does not affect your throwout bearing, in fact it will take pressure OFF of your throwout bearing if it does anything at all. When the clutch pedal is fully disengaged, there should be little or no pressure between your throwout bearing and your pressure plate. One problem could be that your clutch system needs adjustment, if the throwout bearing is resting on the pressure plate when it is disengaged, it will cause LOTS of unnecessary wear. Someone else might be able to chyme in and give instructions on how to diagnose the problem.
One thing you could try to fix the squeaking is spraying some white lithium grese, onto the throwout bearing, through the boot that covers the fork that holds the throwout bearing, the only problem would be getting grease on your clutch plate/pressure plate, which is bad. Do so at your own risk!
Old Sep 3, 2006 | 12:14 PM
  #148
OutdoorLiving's Avatar
Just preformed this mod. One of the best things I ever did to my 4Runner!!
Picked up a spring replacement kit at Advanced. I believe I replaced it with a 6x7/16th spring but ended up cutting about a half inch off each end to get me more pressure. Discovered that my squeek is still there (from the piston goiing into the MC?) but I love the change in pressure on the clutch!
Old Sep 3, 2006 | 08:14 PM
  #149
Bob_98SR5's Avatar
outdoor,
yes, i had the same experience. it was the MC. change both the MC and slave cylinder at the same time too
bob
Old Sep 4, 2006 | 06:33 AM
  #150
dragr1's Avatar
Mine also squeaked after the spring replacement-just added a little lubricant and no more squeak.
Old Sep 5, 2006 | 03:03 AM
  #151
Added pics of my replacement spring:
Old Sep 7, 2006 | 11:55 AM
  #152
bthjash's Avatar
cool fix, but new problem showed up
Hey all, thanks for the great fix! last week my clutch pedal went to the floor and would not return without some assistance. It did this to me once before and being naive as I am, I took it to a service center and they told me that the master cylinder needed to be replaced. So, a couple of hundred dollars later, the pedal operated normal. I thought I was in the clear, until last week. This time I did a little searching online and came upon this forum with this awesome fix. I followed the advice and pulled the large spring off and noticed that the groove worn into the clutch pedal mechanism was so deep that the large spring was actually pushing the pedal to the floor. Jeesh! Stupid engineers!
So, now the pedal is back to normal, but a new problem was lying underneath. Now my clutch is not acting normal. Instead of having the normal 2 or 3" of travel in order to get the clutch engaged, I have about .5" of travel. Which makes shifting a chore. There is a fine line between popping the clutch and wasting rubber on the road, and killing the damn thing. Frustrating! Does anybody have any ideas what might have happened? This was not a problem until the pedal went to the floor and didn't return. I wouldn't think that having a spring related pedal problem could cause a clutch problem.
Please Help! I'm lost.
Old Jul 14, 2007 | 01:37 PM
  #153
rimpainter.com's Avatar
Another satisfied customer. This works great!
I went to Autozone and found a Help! Spring Assortment pack. There is a 6" spring in the pack that will work if you trim one of the ends down a bit. This fix cost me $3.99 and about 15 minutes vs. $25 and 3 hours. Sweet!
I elected not to trim off the bushing/spring bracket on the pedal assembly. It rubs ever so slightly but not enough to be of worry.
Old Jul 26, 2007 | 07:10 PM
  #154
Mr. Taco's Avatar
What a great mod. I did mine this evening. Thank you, thank you, thank you.!
On side note, while looking for a spring I ran into a former Ford parts manager. He said when Ford used this type of over the top spring, it put so much stress on the firewall that Ford had to provide a firewall reinforcement kit on warranty.
Old Jul 27, 2007 | 12:53 PM
  #155
mokai's Avatar
I have an 03 Taco with occasional clutch pedal squeak..Will this fix work on mine or is it a different issue..I have had the bushing replaced before under warranty..It has not squeaked for some time now but am curious for the future..
Old Jul 27, 2007 | 01:58 PM
  #156
"I have an 03 Taco with occasional clutch pedal squeak..Will this fix work on mine or is it a different issue..I have had the bushing replaced before under warranty..It has not squeaked for some time now but am curious for the future.."
Maybe but the squeaking sounds I get are related the pivot arm in the Clutch bell housing and not the pedal. See previous page.
Old Jul 27, 2007 | 06:40 PM
  #157
Mr. Taco's Avatar
An extra, I have always hated the clutch pedal feel. That's gone now and it feels wonderful. This is one of those small tweaks that makes a huge difference. Thanks again.
Old Jan 6, 2008 | 03:18 PM
  #158
owen1832's Avatar
Originally Posted by bildo
I just did the spring swap tonight. Like some of the other folks, I wasn't able to find the #70 spring. Instead I used one of the earlier suggestions and bought the spring from Napa. As shown in the pics below, you get two springs per box. It cost me $3.22. I chose to go with a length of 5.5". So far it's great. It creates a noticeably stiffer pedal but NO MORE SQUEEKING! That squeeking was driving me absolutely crazy.
These can be had on Amazon:
http://www.amazon.com/Help-29007-Uni.../dp/B000COCQW4
Enjoy!
Owen
Old Jan 14, 2008 | 10:16 AM
  #159
ok, I had enough of the heavy stock spring after returning from driving multiple smooth operating manuals while on holidays in Europe (nice diesels over there too but that is for another thread). But I didn't find the torsion spring that easy to remove. How did you guys get it out? Levering with a big screwdriver and watch out or what??
Thanks
edit: I got it out but the feel is pretty similar
Old Jan 15, 2008 | 08:28 AM
  #160
So now that it is out, what is making the clutch hard/stiff to depress? Master or slave cylinder not working properly or is this the normal feel? I will not need a return spring as hard as it is still.I should probably have left the torsion spring as it would actually have helped against the stiffness (with a knee injury and back problem a stiff clutch is a problem).
