Figures and numbers, 1st gen oil leak
Old Aug 17, 2004 | 11:25 AM
phorunninduke's Avatar
Well at 215,000 the oil is now pouring out at roughly 2 quarts per tank of gas. It is such a mess that i can not tell where it is leaking from. It is predominatly the passenger front side. with the lower gaskets being more suspect.
As some of you may recall I cut my finger off a while back, although it has been been re attached and is healing well, i cant use that hand well so most all shade tree work is impossible. So i am looking for some ideas and cost estimates when I drive this thing into a shop./
Old Aug 17, 2004 | 02:53 PM
nunsa's Avatar
I would start with a good steam cleaning and go from there! Once she's all cleaned up you'll have an idea of where the leaks are coming from, otherwise some shop will replace every gasket you have!
Good Luck!
Harry
Old Aug 17, 2004 | 03:05 PM
seaflea's Avatar
Could be the front main seal. Not hard to replace and very inexpensive too.
It took me about an hour to replace mine. I would start with that. I know mine went bad around 200,000 miles
EDIT: just saw you have the V6. cant realy help you on the time frame to fix it.
Old Aug 20, 2004 | 07:18 PM
mtnfreak's Avatar
Do you normally park in a front-down position? If so, I'm betting on the valve cover gasket. If not, it's still worth looking at; the V6's have a history of leaking there.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
