fender flares to cover rust
Old Aug 4, 2004 | 07:24 PM
Chapman88SR5's Avatar
is there a problem with doing that?
if there isnt is there any way i could custom make fender flares? if so what materials
Old Aug 4, 2004 | 07:29 PM
BajaRunner's Avatar
Your gonna want to get rid of the rust first off, otherwise its just going to get worse!
Old Aug 4, 2004 | 07:30 PM
its more big holes above the fenders
Old Aug 5, 2004 | 04:11 AM
how hard do u think it would be to form a new fender out of diamond plated aluminum?
Old Aug 5, 2004 | 04:19 AM
jacksonpt's Avatar
Senior Member
Definitely fix/patch the rust before you cover it up - it will get worse otherwise.
In terms of a new fender - if all you're doing is cutting a piece of diamond plate, it can be done (farily easily too) if you have the right tools.
Old Aug 5, 2004 | 04:58 AM
grams72's Avatar
If your looking at fixing the font fenders, Just go out and buy new ones. Their only $50 +/-.
As for the Diamond plate, unless you have an english wheel you will not be able to form the curves.
Old Aug 5, 2004 | 05:23 AM
4Hummer's Avatar
When I was shopping around for Diamond Plate to finish off my "Chop" I came across Aluminum Diamond Plate that was pretty thin. and formable
You could cut this stuff with tin snips.... I was thinking of using this stuff as a sort of rock guard along the bottom of the doors. So I don’t see a problem using it for fender trim.
You will however want to at LEAST cut the rust out and seal it instead of just covering it up
Old Aug 5, 2004 | 05:27 AM
grams72's Avatar
You can give it a try but unless your a bodyman or a "metal" guy your really going to have a problem getting a complex curv out of an arc.
Old Aug 5, 2004 | 11:57 AM
yeah i was guna cut at least an inch above the rust to get to the good sheet metal b4 i do anything
Old Aug 5, 2004 | 12:01 PM
Lightbulb
i havent found them that cheap yet, where are they?
Old Aug 5, 2004 | 06:45 PM
FSRBIKER's Avatar
I covered my rust over with these flares for now.
http://store.yahoo.com/rodi/pac52170.html
Not sure what I am going to do yet, adapt new 1/4's from the pickup ones available or just cut away and make new inner fender wells to fit the 35's or 37's i am going to run. It's nice to have the tools and can't wait to finish my new shop in my backyard.
Old Aug 6, 2004 | 05:38 AM
grams72's Avatar
I think we got my from Certifit.
Old Aug 6, 2004 | 05:43 AM
grams72's Avatar
How about some pics???
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
skebe22RTE
Jul 31, 2015 02:03 PM
defrag4
Jul 31, 2015 10:50 AM
