Fatty Fender Flare Mud Flaps (Pics)
Old Jun 18, 2006 | 07:30 AM
88XtraCabDLX's Avatar
Thumbs up Fatty Fender Flare Mud Flaps (Pics)
I have the answer... or what I did...
Two Bolt holes line Rite up the inner one uses a plastic square nut the center uses the screw hole that is left over from the running board removal. The outside I used a self tapper...
A front shot...
The info... The Mud Flaps are from a 87-88 4X4 Toyota pick up (I have both one is a 87 parts truck the other is My 88 Xtra Cab the Flaps are the same on both.) If you order new the Part number has changed a few times and they no longer say TOYOTA on the bottom.
What da ya think?
Old Jun 18, 2006 | 08:33 AM
UNR.Grad's Avatar
On my dad's 97 SR5 we found some OEM flaps for the front that are similar to the rear OEM's. They fit our trucks body style a lot better IMHO. But those are effective and get the job done, and that's really all they're there for.
Old Jun 18, 2006 | 09:14 AM
Godzilla's Avatar
I like!...but thats cause I did this before as well.. I also painted the toyota letters to stand out a bit.
https://www.yotatech.com/forums/show...dflaps+limited
Old Jun 18, 2006 | 05:07 PM
OutdoorLiving's Avatar
I like. This is a future mod for me when I come up with a replacement pair and experiement with different flares, etc.
Old Jun 18, 2006 | 06:00 PM
aowRS's Avatar
I did an identical mod to my newly-purchased '01 a month or so after buying it. It was obvious to me that the front 'splash guards' would have zero effectiveness against flying stones chipping the rocker areas. In my case, I picked up a new set of 4WD, V6 Tacoma front flaps. Two of the three holes were a perfect match - the third I simply drilled the flap to match the existing mount on my 4Runner.
5 years later and my rocker panels are chip free.
Andreas
Old Jun 19, 2006 | 05:52 AM
Recall the approximate cost for those mudflaps?
Old Jun 19, 2006 | 05:55 AM
aowRS's Avatar
I believe they were around $60 each. Seemed pretty damn expensive at the time but have been worth every penny.
Andreas
Old Jun 19, 2006 | 08:42 AM
Thanx Guys
Andreas
This is why I went with these I wanted to keep the stone chips away.
I also ordered the new flaps for an 88 to see what comes so I'll snap a Pic and post price and part # when they get here.
Old Jun 21, 2006 | 05:30 PM
Lightbulb
Okay the new flaps showed up today...
Pros looks like they'll bolt on with existing holes
Cons way to short for me just under 4 inches shorter then the ones I already put on. They're about 21 dollors each.
Here's some pic so you can see if they'll work for you...
Image Hosting at Bolt
Old Jun 21, 2006 | 05:34 PM
Spectre's Avatar
Would it be possible to see some non-closeup pictures? so I can see how they look on your runner??
Old Jun 21, 2006 | 05:59 PM
Intrepid's Avatar
Those are great, so great in fact, that I would rip them off the very first time I drove off the tar. I ripped off my two front ones, replaced them, and ripped them off immediately. Mudflaps that don't disconnect easily are a waste of money unless you are a street truck only, and even then they aren't pretty.
Old Jun 21, 2006 | 06:01 PM
Do you want some with the long flaps I put on? I'll try to take some tomorrow. I wasn't planning on putting the short ones on, but i could just for pics if you want.
Old Jun 22, 2006 | 04:09 AM
Andreas
Wow, $60 a pop? My fenders are already chipped to hell.
rusty904
Mar 27, 2017 05:20 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
mr_manny
Jul 31, 2015 10:39 AM
coffey50
Jul 28, 2015 10:55 AM
