to fast?
Old Feb 25, 2004 | 03:15 PM
BigJohn's Avatar
to fast?
I was going 110 for about 10 min straigh ton the highway is this bad for it
Old Feb 25, 2004 | 03:20 PM
Andrey's Avatar
You could have gotten the ticket... that's bad
As far as engine, you have absolutely nothing to worry about. 4Runners are put through way more abuse than that and still run flawlessly!
-- Andrey
Old Feb 25, 2004 | 03:23 PM
4x4Lamm's Avatar
can't be easy on anything, your tires are prob. not rated to go that fast, but most importantly... IT'S NOT GOOD FOR YOU AND OTHER DRIVERS!!! High speed MVAs are nightmares, just think of the other people you could so easily kill, slow it down friend.
Lamm
Old Feb 25, 2004 | 03:25 PM
86toyota's Avatar
I wish mine could do 110
Old Feb 25, 2004 | 03:27 PM
BigJohn's Avatar
i know after i was done going this fast i had a wobble i think it was tires or something but it went away.
it was 3am there where no cars on the highway
Old Feb 25, 2004 | 03:31 PM
Vato Loco's Avatar
Don't worry about it, now this is abuse:
Old Feb 25, 2004 | 03:35 PM
amusement's Avatar
A few years ago I took my Taco 2.4L for a lonely drove on long stretch of California highway 395. No one else was on the highway. I got 112mph. Didn't like the sheet metal in the hood bending in the wind. Still had a 1/3 of the pedal to go. No mods just stock x-tra cab with 5 speed.
Old Feb 25, 2004 | 03:37 PM
BigJohn's Avatar
the speed governor kept kicking in it sucked
Old Feb 25, 2004 | 03:38 PM
amusement's Avatar
Isn't 110 your take off speed.
I hate to see what kind of air dam you will need to take the air from going under you.
I would suggest a a wing from a pipper cub to keep the rear end down.
My very former '93 T-bird had a stall setup. When you reached 90 or so the engine would turn off. That's right! Then engine would turn off. Made braking and steering a little heard without the power. Armstrong steering.
Old Feb 25, 2004 | 03:52 PM
lunatic14r's Avatar
drive fast take chances
Old Feb 25, 2004 | 04:19 PM
UKMyers's Avatar
Why even bother posting stuff like this? All that's going to happen is people are going to tell you to slow down you were driving too fast. If you were worried something bad was going on with your truck then why'd the hell did you do it..?? That's like asking I was out jumping my truck 10 feet high last nite.. think that was bad for it? Or I hit a speed bump 5 mph think I knocked my alignment out?
Old Feb 25, 2004 | 04:34 PM
kford's Avatar
my governor on my 97 kicks in at about 104-106. But anyway, ITS A 4RUNNER... It's not made for high speeds. Yeah it can handle it without breaking, but at those speeds, brakes are just about useless, adding to all the dangers. The suspension is not made for high speeds and maneuvering.
Plus, you probably just wasted about a half a tank of gas going that fast. I used to cruise around 85mph on interstate, and now that i've cut it down to 70-75, I have noticed a significant increase in mpg.
And i know my BF Goody T/A's don't like high speeds. No truck tires do. Slow down!
Old Feb 25, 2004 | 05:10 PM
scharged03's Avatar
don't give me any ideas.
Pitchar
Old Feb 26, 2004 | 06:28 AM
Unhappy99's Avatar
Since 110 Canadian is about 69 U.S., the 4Runner should survive. Besides, what happens in Canada stays in Canada.
Old Feb 26, 2004 | 07:10 AM
foxtrapper's Avatar
Guest
Tire tread separation or carcass failure are your biggies when doing this. Offroad tires frequently aren't design for the heat and centrifugal forces this kind of speed puts on them.
Old Feb 26, 2004 | 07:15 AM
Churnd's Avatar
Yeah, your tires have speed ratings on them. I think 100 might be the most the typical truck tire is rated for. You go over that speed, you're taking a gamble.
Old Feb 26, 2004 | 07:16 AM
Churnd's Avatar
Oh yeah, were you talking in km/h or mph?
Old Feb 26, 2004 | 04:18 PM
lunatic14r's Avatar
are you scaired of speed
Old Feb 26, 2004 | 04:54 PM
kford's Avatar
too furious!!!!
Old Feb 26, 2004 | 05:08 PM
chuckd's Avatar
Does the 4runner doing a burnout have Pathfinder wheels on it? And if so, why?
