Failed Smog Check
Old Mar 13, 2007 | 04:38 PM
igogusto's Avatar
I passed smog barely, I was at the max for NOx at 15 Mph. To pass, I had to put my wife's stock rims on the rear. This is going to be a pain for future smog checks, but at least I am good for the next 2 years!!!
(_)3 Cheers!!
Old Mar 13, 2007 | 04:55 PM
wjwerdna's Avatar
smog?? wth are you talking about? yeah there is smog everywhere around here... NOx testing? huh???
I searched but I can't find an explanation as to what this "SMOG" is
edit: NM sorry forgot I'm in MI...
but yeah, it'd be nice if we even had some regulations
Old Mar 13, 2007 | 05:01 PM
MTL_4runner's Avatar
Michigan sounds alot like up here in Canada too.
.....so what is this smog inspection anyway?
Old Mar 13, 2007 | 05:06 PM
HUTCHSTACO's Avatar
a pass is all that matters, how often do you have to get tested
Old Mar 13, 2007 | 05:11 PM
  #25
igogusto's Avatar
The Smog Inspection measures emissions and has to be done every 2 years in California.
Old Mar 13, 2007 | 05:27 PM
  #26
I was kidding.....I used to live in AZ so I'm all too familair with it unfortunately.
Old Mar 13, 2007 | 06:28 PM
  #27
BruceTS's Avatar
You still have issues, tire size shouldn't matter that much. I pass smog every time running 35's, yes I'm regeared, but before then I had larger tires on stock gears and it still passed.
Old Mar 14, 2007 | 04:16 AM
  #28
That's what I was thinking as well......the tire size band-aid just allowed you to squeak under the bar.
Old Mar 15, 2007 | 06:43 AM
  #29
ErikB's Avatar
I had high NOx and a new pre-cat o2 sensor was the fix. This was on my '97 runner with stock gears and 285's. As others mentioned, tire size should not be an issue.
Pretty sure the same thing happened on my '97 T100 (35's), but that was a while ago so I can't quite remember the details.
The o2 sensors just seem to wear out after a while and then they tend to run lean.
Old Mar 15, 2007 | 03:17 PM
  #30
crazy_horse3030's Avatar
just try to seafoam. I have used it a lot, it works good on cleaning. I am just interested in how it does with emissions.
Old Nov 7, 2007 | 08:19 PM
  #31
KUMAdrift's Avatar
AHHHHH! i also failed my smog check ! plz help!
failed 15mph test NO (PPM)- i failed that, everything else passed
pass 25mph test
i have stock everything except for a 2" lift w/ 33's on. i have tried 3 times each mech saying different things that it might be. 1." u have to get a new egr valve" which i dont think i even have, 2. "replace ur tires with stock", 3. "get a new cat". man i dont know what to do .
so from reading the thread i think i should clean the maf and do a seafoam thing?
Old Nov 7, 2007 | 08:37 PM
  #32
ErikB's Avatar
My experience with these engines has been that high NO is a result of running lean (too hot) and it is caused by the forward oxygen sensor going bad. I'll betcha a new sensor is the fix. Especially if you're anywhere near the 100-120k mark.
Old Nov 8, 2007 | 05:06 AM
  #33
Clean the heck out of your MAF with brake cleaner, pull the neg batt terminal and have it retested at a shop.
Old Nov 12, 2007 | 04:10 PM
  #34
KUMAdrift's Avatar
ok, so i cleaned the maf and did a fuel system clean. plus i went to the dealer and got a 120k tune up. and i still failed. big time failure. before i did everythign it was max NOx 580 and i got 620 ... now i have 1600 at 15mph and this time i didnt pass my 25mph test either . dang what should i do now!!!
Old Nov 12, 2007 | 04:11 PM
  #35
KUMAdrift's Avatar
you guys think i should change my o2 sensor might make a difference?
Old Nov 12, 2007 | 04:48 PM
  #36
Sounds very lean right now (ie the problem you were having should now be alot easier to track down because it is so far out of spec). You can replace your A/F sensor, but I'd have toyota hook it up to their diagnostic and look at all the sensors before you just start playing parts replacement.
Old Nov 13, 2007 | 06:26 AM
  #37
Ian Rogers's Avatar
are you using chevron 87, did you bring the truck in HOT and keep it running wail you waited? Have you changed the oil of late?
Old Nov 13, 2007 | 12:11 PM
  #38
KUMAdrift's Avatar
my friend recommended premium gas so i think that contributed to my high NOx. but yea truck was hot an the oil was changed recently.
i think i might have to go to the mech for this cuz its way outta whack.
Old Nov 13, 2007 | 08:38 PM
  #39
Ian Rogers's Avatar
ok ... lets get chevron 87 in the tank(run at least 3 tanks), and stock sized tries on the truck. These two things will make it pass( you only need to find 2 tires to change out the rear.)
Old Nov 13, 2007 | 08:54 PM
  #40
KUMAdrift's Avatar
thanks ill try that.but if anything ill prolly just pay the guy off cuz going to a mech is gonna cost me a fortune.
