Failed Smog Check
Old Nov 13, 2007 | 10:19 PM
  #41
osker fenix's Avatar
Originally Posted by igogusto
I passed smog barely, I was at the max for NOx at 15 miles per hour. To pass, I had to put my wife's stock rims on the rear. This is going to be a pain for future smog checks, but at least I am good for the next 2 years!!!
(_)3 Cheers!!
Since when do they require a smog check at certain speeds, i just did a smog check on my blazer last week and all they did was park it and rev it. They had the dyno looking machine but didnt put my truck on it.
Old Nov 14, 2007 | 06:01 AM
  #42
Ian Rogers's Avatar
Well I would guess that your blazer is AWD and cant be tested on a 2 wheel Dyno. All of my cars and truck with the exception of my fj40 have had dyno runs for smog checks.
Old Nov 14, 2007 | 05:21 PM
  #43
nope RWD.
Old Nov 14, 2007 | 05:30 PM
  #44
infiltrator's Avatar
i just got my smog check less than a week ago.
i too live in california, and hate smogs... i have a couple questions
is your 4runner made and bought in california? if so i think it might have some extra thing on the engine. if not, maybe that accounts for something
i have 31'' tires and i passed my smog with flying colors? i waited till AFTER smog to do seafoam, in case of the check engine light.
MY TRICK: run a tank full of CHEVRON low emissions gasoline, run it on the freeway before to warm everything up, and you should be golden..
after all ive passed for 13 years now :]
Old Dec 9, 2007 | 08:56 PM
  #45
KUMAdrift's Avatar
HAHAHA i finally passed .. the new mech just replaced the o2 sensor and i passed. geez but fixing it was my last choice...(cost more money to fix than to cheat) anyways im happy .. no lookin for cops behind me now!
Old Dec 19, 2007 | 01:45 PM
  #46
Man4God's Avatar
First off, NO CARB CLEANER on the MAF. Only electrical sensor cleaner.
Second, if it is due to a lean condition, you might consider replacing your fuel filter as well. Anything that restricts fuel flow or makes the computer run lean is something to look for. A new thermostat might help too.
I am due for a smog check as well. Not looking forward to it. Just about as much fun as a prostate exam.
Old Dec 19, 2007 | 11:16 PM
  #47
i hate smog checks they always take forever and leave you in the prayer position the whole time hoping its gonna pass. Then when you see PASS its *sigh of relief* ...hopefully
Old Dec 19, 2007 | 11:32 PM
  #48
stormin94's Avatar
If you have to go to a check only station, and you meet income requirements, the state of California will pay up to $500 to get your vehicle fixed so it will pass. Or they give you the option of retiring your vehicle, and they will pay you for it. Good to hear you passed, though.
Old Dec 20, 2007 | 06:58 PM
  #49
Dare44's Avatar
the place i go never puts it on a dyno or revs it they just check it at idle and tell u its good and never had a truck fail yet (knock on wood), guy said he can usually tell if its going to pass by the smell when u pull up
Old Jan 1, 2008 | 04:22 PM
  #50
ErikB's Avatar
Originally Posted by ErikB
I had high NOx and a new pre-cat o2 sensor was the fix. This was on my '97 runner with stock gears and 285's. As others mentioned, tire size should not be an issue.
Pretty sure the same thing happened on my '97 T100 (35's), but that was a while ago so I can't quite remember the details.
The o2 sensors just seem to wear out after a while and then they tend to run lean.
My experience with these engines has been that high NO is a result of running lean (too hot) and it is caused by the forward oxygen sensor going bad. I'll betcha a new sensor is the fix. Especially if you're anywhere near the 100-120k mark.
Wow........ who'da thunk!?!?
Old Aug 4, 2008 | 06:49 PM
  #51
chicktruck's Avatar
are you kidding. didn't pass because of wheels/tires. i have the stock alloys with 265/75/16, basically 32"s and i can't pass the 15mph nox. but it passed when i bought it and it had 16x8 rims and 305's. but they did it at a lower rpm. maybe that is my problem.
98 4runner
Old Feb 5, 2009 | 03:53 PM
  #52
bkerwin's Avatar
Swapping o2 sensors
Does anyone know if I can swap out my O2 sensor from my 2000 4runner into my 97 just to get past the smog?
Oh, and I do have one of those code checkers, but the check engine light isn't on in the 97 that failed smog. Might there be useful codes in there even if the light isn't on? I had high NO at 15mph, 25mph passed ok.
Update: My 2000 is dual cat with two sensors, the 97 is single cat and I only see one sensor.
jasonty
41
Dec 23, 2018 01:00 PM
PNWrider
Oct 30, 2015 08:14 AM
shisha1999
Sep 21, 2015 08:22 PM
kvanzandt1
Jul 18, 2015 10:15 AM
timmJ
Jul 7, 2015 02:01 PM
