Extending Front Diff. Breather Question
Old Apr 3, 2003 | 02:49 PM
ATC's Avatar
ATC
I am attempting to extend the breather on the front diff. but the 90 deg. union fitting will not fit. There is not enough room for me to turn it to screw it into the top of the diff. The part I am trying to use is p/n 90904-04001. This is the same p/n listed on previous Threads regarding this mod.
Old Apr 3, 2003 | 04:23 PM
RTdawgs's Avatar
i thought the front breathers were already in the engine compartment.
Old Apr 3, 2003 | 04:29 PM
ATC's Avatar
ATC
Not on my '95 4Runner. I have extended both the rear diff & the transfer case breathers. I have run both of them into the engine bay.
Old Apr 3, 2003 | 06:05 PM
Bumpin' Yota's Avatar
i STILL havent been able to locate my tranny's breathers, nor extend the current breathers due to time restrictions, but my 2nd gen had none of the other breathers exteneded....how stupid of toyota.
Steve
Old Apr 3, 2003 | 06:07 PM
914runner's Avatar
hey ATC how did you extend the transfercase breathers? i thought that they were press fitted?
Thanks
Old Apr 3, 2003 | 06:09 PM
Thanks
I havent pulled that one yet, but to my fingers it feels like it screws in just like the differential breathers.
Corey's Avatar
Co-Founder/Administrator
Oh crap, I have the exact same part in front of me as I type.
I know it's a tight fit in there, as I gave up over a year ago trying to put a straight one in.
I was hoping to put this one in soon, as I just bought it a few weeks back.
Old Apr 3, 2003 | 08:23 PM
ATC's Avatar
ATC
Corey, The best I can figure is that the front case would have to be taken apart to make this 90 deg union work. It simply will not turn much past 1/4 turn before it hits the case.
I guess I will order a straight union & p/u a 90 deg rubber fitting & see if that might fit.
914runner, It's the same breather that both the front & rear diffs have. I simply unscrewed it & replaced it w/ the same 90 deg union I attempted to put in the front diff. case. A straight one would be to tight once a hose is put on it.
Old Apr 3, 2003 | 09:26 PM
upndair's Avatar
Steve
The Tranny and t-case breathers are on TOP of the tranny and t-case. You can get at them through the floor if you pull the center console, shifters etc. It's a lot easier if you have a body lift...
Old Apr 3, 2003 | 09:28 PM
upndair's Avatar
You don't need a 90 degree anything. I got a $1 barbed fitting from Lowes, Screwed it in, attached a hose to the barbed end and added a hose clamp. It's a very simple modification and cheap.
Old Apr 3, 2003 | 10:36 PM
Robinhood150's Avatar
I just did my front one. I poped the cap off the stock breather and slipped the tube over the end of the breather with a hose clamp. It's a bit harder to find a tube large enough to fit over the breather and can withstand the temperature of the engine. I need to switch my tube I used, because I don't think it can handle the temps. The transfer case breather is easy to get to, I saw it the other day while I was hanging out under the truck.
Steve
Old Apr 4, 2003 | 03:20 AM
ATC's Avatar
ATC
upndair, I was told that the tranny on an automatic used the dipstick tube as its breather.
Is that true? Just looking for a 2nd opinion.
Thanks for the tip on Lowes. Guess I'll have to go ck that out.
Old Apr 4, 2003 | 04:49 AM
No body lift here... I found the transfercase breather, but the two tranny breathers have eluded me thus far. Thanks for the help bro!
Steve
Old Apr 4, 2003 | 06:00 AM
upndair's Avatar
I don't know where the breather is on the auto tranny.
Take your existing breather out, head over to Lowes. Find the display with the barbed fittings. You'll find an exact match to the threaded portion of your breather. Then using a hose (I used fuel line.) Clamp the fuel line to the barbed bitting and run it up to the top of the engine compartment somewhere. I used a cheap fuel filted on the upper end to cap off the top of the hose.
When running from the back, I T'd the breather lines from the Tranny and T-case so that I had a single rear line coming up in the engine compartment.
Old Apr 4, 2003 | 07:22 AM
mtnfreak's Avatar
For the front breather on my '89, I just popped the cap off and slipped a hose over the stub. I used a little sealant and a hose clamp since there's not much to hold onto. I'm a little worried about how the hose will handle the heat this summer, but so far it seems to be fine.
For the rear, I used a 90 degree fitting - it directed the hose away from the exhaust and made it easier to allow for axle movement without making the hose sag.
I've seen the t-case breather - it's the same as the diffs. I'd like to work on it, but it looks like I'd have to run a hose forward along the top of the t-case & tranny to the rear of the engine and then up. Either that or drill through the floor and come up into the center console.
Haven't seen the breather(s) for the auto tranny. Not sure if there are any or if the dipstick is it.
Old Apr 18, 2003 | 05:08 PM
rabidbeaverbaby's Avatar
anybody know for sure how the auto tranny on a 2nd gen breathes?? is it the dipstick? or are their breathers??
88sasturbotoy
Jan 30, 2026 01:57 PM
kazuya2416
Apr 5, 2024 02:17 AM
oldirtydirt
Feb 23, 2020 09:30 AM
icentropy
Jul 14, 2015 10:23 AM
Nickdigg
Jul 7, 2015 06:04 AM
