Extended Breather Parts
Old Mar 18, 2003 | 08:01 PM
ATC's Avatar
ATC
What good is the dealer???
Monday I ordered the parts so I could install extended breather on my differentials. The dealer told me they would be in by 4pm Tuesday & now they tell me there back ordered.
I have been searching around for the site where someone had ordered their parts from someplace other than the dealer. Does anyone have that info?
Thanks
Old Mar 18, 2003 | 08:19 PM
4x4CPOSEADOG's Avatar
Which parts did you order?
Old Mar 18, 2003 | 08:27 PM
ATC's Avatar
ATC
2 Breathers # 90930-03136
1 Union # 90404-51319
1 90 deg. Union # 90904-04001
Old Mar 18, 2003 | 08:38 PM
Firefyter-Emt's Avatar
Here is a write up for using the Nissan parts..
lookie here
Old Mar 18, 2003 | 08:44 PM
ATC's Avatar
ATC
Thanks for the link. Do you know if that part will also work on the front? I thought that was why a 90 deg was needed due to the lack of room.
Old Mar 18, 2003 | 08:57 PM
it will work with a little tweak on them.. I have them up front on mine (all stock) You do need to just bend it to one side a hair..
But, if I had it to do again I would get the Toy parts for it..
Old Mar 19, 2003 | 08:09 AM
Mad Chemist's Avatar
http://www.toyotaparts4u.com/
This where I bought the toyota parts from.
Old Mar 19, 2003 | 09:56 AM
jharris2's Avatar
Got mine at http://www.toyotaworld.com
Old Mar 19, 2003 | 10:23 AM
ATC's Avatar
ATC
Thats the info I was looking for.
Thanks
Old Mar 19, 2003 | 06:01 PM
1Runner's Avatar
You just use vacuum line for the extended run then?? I was planning to do this this spring. Thanks for the part # ATC!
Old Mar 19, 2003 | 06:24 PM
ATC's Avatar
ATC
Yeah from what I have read you use 3/8" fuel, air or vac hose.
Old Mar 19, 2003 | 06:25 PM
jharris2's Avatar
I used 5/16" fuel line. Others have used 3/8" fuel line, but I thought it was a bit too large. 5/16" was a good, snug fit.
Old Mar 19, 2003 | 09:31 PM
upndair's Avatar
I got mine a Lowes. A simple brass barbed fitting threaded directly in. A fuel line takes the front and rear diffs, transfer case and transmission all terminate at the top of the engine compartment, right by the clutch master cylinder.
Oh year, I had a couple of hose clamps too.
Old Mar 20, 2003 | 07:05 PM
Guys,
I'm doing a little research right now about the flare to metric adapter that will fit in those diffs. If you guys are interested in stainless steel braided lines to modify or upgrade your existing breathers I will give you the part number as soon as I've modified mine. I will give it a try first and if it works, I will post it on this board.
Noel
Road Bull
Oct 10, 2015 04:55 PM
Sep 4, 2015 09:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
Nickdigg
Jul 7, 2015 06:04 AM
