this is an evil site!!!! spacer ? guys
Old Nov 25, 2003 | 07:44 AM
Corey's Avatar
Co-Founder/Administrator
Originally posted by doink
i was trying to avoid getting aftermarket t bars when i got my arb and winch up front. i just couldnt handle all the nose dives i was doing whenever i braked/went over speed bumps.
Exactly.
I could not take the nose diving for more than a few weeks.
It was unsafe to drive.
Putting on the 25 mm SAW T bars made it enjoyable again to drive.
I do have mine cranked up about 1.5" or so, and manual hubs.
I would not do the 25 mm bars unless there is a winch added to an aftermarket bumper.
Old Nov 25, 2003 | 08:23 AM
Cebby's Avatar
Re: Epitome
Originally posted by waskillywabbit
But who on here besides me, you and Flyg would know what "epitome" means?
How's the air up there?
Old Nov 25, 2003 | 08:56 AM
Robinhood150's Avatar
Re: Thanks guys
Originally posted by bigKahuna
I was able to stuff the 15x10 with 31x10.5 with no rubbing and not blowing a bead at 18lbs pressure (lucky so far) I want wider without the high cost and trade off of increased problems. Maybe even using 31x11.5 or even 31x12.5 as I dont need the clearance. (Not doing the rubicon or large rocks anytime soon)
18 PSI is still high for pismo. Try 12 or even lower. I'm running 15x7 rims with 32x11.5 tires and I'm fine running 12.
Old Nov 25, 2003 | 09:08 AM
Flygtenstein's Avatar
Getting 33's on is not a big deal unless you want to run them on a 10" wide rim.
Mike, funny.
You are running a 31x10.5 on a 10" rim? Wow.
I have my 25mm bars barely cranked, very slight. I could not hit my compression stops if I tried. I can stand on the front of the truck now, weighing all of 265 pounds, and it does not compress. I have lifted rear tires and still not had the front compress to the bumpstops. I hope to change that over break, but I think this is worth pointing out.
Old Nov 25, 2003 | 09:14 AM
  #25
UKMyers's Avatar
Mine is the same way with my Bils and NO T-bar crank.
Old Nov 25, 2003 | 10:20 AM
  #26
waskillywabbit's Avatar
Re: Re: Epitome
Tastes like chicken, smells like steak!
Sep 4, 2015 09:27 AM
Poppie51
Jul 23, 2015 05:03 PM
highonpottery
7
Jul 18, 2015 02:48 PM
timmJ
Jul 7, 2015 02:01 PM
ptb12
Jul 5, 2015 01:49 PM
