this is an evil site!!!! spacer ? guys
Co-Founder/Administrator
Originally posted by doink
i was trying to avoid getting aftermarket t bars when i got my arb and winch up front. i just couldnt handle all the nose dives i was doing whenever i braked/went over speed bumps.
I could not take the nose diving for more than a few weeks.
It was unsafe to drive.
Putting on the 25 mm SAW T bars made it enjoyable again to drive.
I do have mine cranked up about 1.5" or so, and manual hubs.
I would not do the 25 mm bars unless there is a winch added to an aftermarket bumper.
Re: Epitome
Originally posted by waskillywabbit
But who on here besides me, you and Flyg would know what "epitome" means?
How's the air up there?
Re: Thanks guys
Originally posted by bigKahuna
I was able to stuff the 15x10 with 31x10.5 with no rubbing and not blowing a bead at 18lbs pressure (lucky so far) I want wider without the high cost and trade off of increased problems. Maybe even using 31x11.5 or even 31x12.5 as I dont need the clearance. (Not doing the rubicon or large rocks anytime soon)
Getting 33's on is not a big deal unless you want to run them on a 10" wide rim.
Mike, funny.
You are running a 31x10.5 on a 10" rim? Wow.
I have my 25mm bars barely cranked, very slight. I could not hit my compression stops if I tried. I can stand on the front of the truck now, weighing all of 265 pounds, and it does not compress. I have lifted rear tires and still not had the front compress to the bumpstops. I hope to change that over break, but I think this is worth pointing out.
Mike, funny.
Sep 4, 2015 09:27 AM
highonpottery
7
Jul 18, 2015 02:48 PM
